did you learn everything about newton before learning to ride a bike?
sometimes it is possible to run before knowing how to walk.
Build a wind turbine
- antoinet111
- Grand Econologue
- Registration: 19/02/06, 18:17
- x 1
Babies sometimes do this, as one of my grandchildren:
and break the face without damage, given their small size.
Otherwise the Romans did not invent the alternator wind turbine, before we understand the electromagnetism, and still, it took 50 years between the discovery of induction 1830 and 1880 to see the first alternators.
So putting the cart before the horse, is rarely effective.
Hello...
I understood ... in fact, Dedeleco, you wouldn't be the site's killjoy? Kind of "moderator" but in a "dark side of the Force" version?
Seriously, who do you think you're helping by making this talk? You intervene a lot of times, you are right, but your side "I know everything, I know everything, you know nothing ...."
If you know, answer the questions instead of balancing your science ...
Tam20 will not get up tomorrow, buy 1000 euros of gear without inquiring! And there, he comes to inquire and you do not help with everything ...
You who know everything, can you answer him? Because that helps people ...
Good day to all
Good day to all
My projects in parallel: http://poeleabois.perso.sfr.fr
Specifically Tam20, for the equipment behind the wind turbine, you want to stay in 12V or go to 220V?
antoinett111 replied:
but it is better to know the characteristics of the battery and the alternator (with its output rectifier, because the batteries only want the direct current and not alternator of the laternator), to know if they are compatible in voltage, in max current and internal resistances !!
The alternator has a no-load voltage which decreases by current flow proportional to its internal resistance so that the output voltage is equal to that of this vacuum battery plus the voltage of the current in the internal resistance of the batteries.
This resulting current must not exceed the maximum allowable current of the battery (nor also in the alternator).
It is much longer to write than to check in reality with some simple calculations if we know a minimum.
Sometimes we are also measuring these internal resistance.
Also, a problem is that the output voltage of the alternator with rectifier, varies depending on the wind and should be cut, if the wind decreases too much, to avoid discharging the battery in the alternator.
So you have to have a clear idea of the precise assembly, the regulator (if it is simplistic diode or sophisticated, with the alternator), etc.
something else, an alternator gives over 12v, it's not a concern for the battery. until you send him 15 or 16v.
Well, from a simple point of view, the use of an alternator to use 12V is:
the diode bridge allows to have a correct current for a battery (it's done for ...)
The converter allows a lot of things behind it.
Two problem then arises:
The power required according to the consumption of 220.
And the problem of alternators that, if they are not permanent magnets, consume current before producing.
you must know according to your alternator, the speed at which it must turn and deduce the speed of your wind turbine and therefore, if that will be enough for your conso ...
Are you interested in alternator "rewinding" or in modifying it to make a permanent magnet alternator ...
I give you only clues because I am studying (and yes dedeleco ...) the subject ...
What type of wind turbine is it? Construction house or recycle bodon metal ...
- Similar topics
- Replies
- views
- Last message
- 0 Replies
- 4511 views
Last message by mauriceboka
View the latest post
30/03/17, 07:19A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 0 Replies
- 3942 views
Last message by rifleman
29/12/15, 22:44A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 38 Replies
- 32531 views
Last message by vinzman
22/07/11, 17:06A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 2 Replies
- 16572 views
Last message by Pierre17800
08/03/09, 08:42A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 16 Replies
- 30345 views
Last message by chatelot16
12/02/18, 00:04A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 185 guests
