Problem of well drilled on sandy ground
I am making a well on sandy ground. When I got to the water (4m from the ground), I put a 160mm PVC tube on which I made small 1,5mm notches. I remove a lot of sand, the pipe that I put down a good meter but my concern is that the sand is so fine that it passes through the holes of the pipe but this sand prevents me from going down more. If anyone can advise me, thank you in advance.
- antoinet111
- Grand Econologue
- Registration: 19/02/06, 18:17
- x 1
Read the 11 pages thoroughly:
https://www.econologie.com/forums/post216304.html#216304
and read the links in it.
- Similar topics
- Replies
- views
- Last message
- 29 Replies
- 16889 views
Last message by oli 80
View the latest post
13/06/21, 11:11A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 11 Replies
- 22725 views
Last message by izentrop
09/02/21, 09:50A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 1 Replies
- 8740 views
Last message by thibr
28/07/18, 07:16A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 3 Replies
- 6626 views
Last message by Ahmed
18/05/18, 22:18A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 7 Replies
- 11734 views
Last message by Bardal
08/04/18, 18:07A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
Who is online ?
Users browsing this forum : No registered users and 230 guests
