Pump runs very often ...
Work concerning plumbing or sanitary water (hot, cold, clean or used). Management, access and use of water at home: drilling, pumping, wells, distribution network, treatment, sanitation, rainwater recovery. Recovery, filtration, depollution, storage processes. Repair of water pumps. Manage, use and save water, desalination and desalination, pollution and water ...
User avatar
Gaston
Registration: 04/10/10, 11:37
x 88
by Gaston » 04/11/11, 10:36
Philippe Schutt wrote:In a balloon without membrane, the volume of air at 0 bars corresponds to the volume of the balloon. With the circuit at minimum pressure (starting threshold of the pump) a good part of the tank is already filled with water (non-elastic).
Exactly.
To quantify a little with a 500 liter balloon with minimum pressure = 3 bars and maximum pressure = 4 bars.
At 0 bar, it contains 500 liters of air.
At 3 bars, it contains 166 liters of air and 334 liters of water
At 4 bars, it contains 125 liters of air and 375 liters of water
The amount of usable water between 3 and 4 bars (between two pump starts) is therefore 375 - 334 = 41 liters.
Philippe Schutt wrote:By preloading the balloon you recover part of this volume for air.
If it is "inflated" to 80% of the minimum pressure (therefore 2,4 bars), it is as if it contained 1200 liters of air at pressure 0.
At 3 bars, it contains 400 liters of air and 100 liters of water
At 4 bars, it contains 300 liters of air and 200 liters of water.
The amount of usable water has increased to 100 liters between two pump starts.
Philippe Schutt wrote:An air leak could cause these symptoms.
Yes, but it is not necessary.
In a balloon without a membrane, the air in the balloon gradually dissolves in water and leaves the balloon.
Air must be periodically supplied either with a compressor or by emptying completely the balloon of its water.
Aurelmouth wrote:I just emptied the booster to see and there was practically no water at the bottom.
When you put it back on the road
- is the drain closed properly?
- does the pressure rise regularly or suddenly?
dedeleco
Registration: 16/01/10, 01:19
x 10
by dedeleco » 04/11/11, 13:35
Totally agree with P Schutt and Gaston and their common sense !!
Having reset the bowl, to pay for a new expansion tank with a rotting membrane every 3 to 5 years, to measure the rapid dissolution rate, rent for heating installers, I moved this boiler expansion tank to the most top of the installation which collects all the gases and therefore never empties, over 20 years of total tranquility !!!
Nothing new, it was the basis of central heating without a circulator by thermosiphon from the 1920s to 1940s !!!
User avatar
Philippe Schutt
Registration: 25/12/05, 18:03
x 33
by Philippe Schutt » 04/11/11, 18:47
This would mean that you have enough air in the balloon. But it is not used, so something the mouth? Valve broken in almost closed position?
  • Similar topics
    Replies
    views
    Last message
Go back to “Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ... "
Who is online ?
Users browsing this forum : No registered users and 112 guests
