Hello,
I work on a TPE I am in 1er SSI and I plan to build a wind turbine at lower cost with recovery materials. Of course we have a budget that belongs to us
what was our inventory?
what is the best solution for a garden wind turbine?
or if possible enlightened us
Thank you for your help
Construction of a wind turbine at a lower cost
- wirbelwind262
- Éconologue good!
- Registration: 29/06/05, 11:58
- x 29
Bonsoir
so, to start: "google can be your friend"> the keywords like DIY windmill should give you inspiration ...
among other things, there is that http://www.onpeutlefaire.com/construire ... e-vertical
also type wind turbines "piggott"
Good luck !
Good luck !
Yes I have already fallen and I have already found several simillary sit has that but the problem that arises and on any material can we used to do the '' mast '' of the wind turbine for example to make the blades we can used can (ex: steel fuel can) cut in four we can used an ex-alternator of scooter, motorcycle .... we had several ideas but for the cental party
There is an armada of wind turbines possible very different configurations !!!
Google and econology well questioned respond very well !!!!
is likely variable response depending on what you get or have cheap and work that we agree to do!
You do not have that wind turbines in top of mat to horizontal axis and fine blades !!
Do you know why they are so and what are their advantages and disadvantages? (basic question asked by a project reviewer of my ilk !!)
The old wind turbines of the Middle Ages or even before are remarkable, well-known windmills are simple in equipment and more work to build them !! They were quite efficient in the sense of the time to grind grains or pump !!
You have wind turbines with simple vertical axis, like a carousel, simple to build !!
Look at all the variants and those for underdeveloped countries.
The easiest way to light is a cheap LED lamp crank operated by a small wind turbine fabric sails !!
A mat bamboo and guy is a Chinese solution!
A mat made from a live tree with the wind turbine up is a solution that requires you to learn how to climb a tall 25m pine or oak tree !!
Recovering the agitation at the top of the trees by the wind with ropes and pulleys, as for the waves on the sea, is an original solution to patent which makes the wind turbine invisible in the forest to the point that the neighbors can not protest, its low efficiency being compensated by the surface of trees in the wind and its aesthetic ecology side. !!
So this project is to test your imagination and your choices!
project to build a wind turbine at lower cost with recovery materials
- Registration: 12/01/07, 08:18
- x 4
Re: Construction of a wind turbine at a lower cost
baptiste wrote:Hello,
Hello,
I have your answer
In front of Charleroi airport in Belgium, two wind turbines were installed on the roof of a state building.
It never worked!
Give the bourgmestre a call to pick her up
Edited to insert the photo:
http://www.charleroi.be/SiteResources/D ... d-3933.htm
Man is by nature a political animal (Aristotle)
- Similar topics
- Replies
- views
- Last message
- 2 Replies
- 7619 views
Last message by BaudouinLabrique
View the latest post
17/05/23, 14:56A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 0 Replies
- 6183 views
Last message by danpat
18/12/18, 05:24A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 6 Replies
- 15757 views
Last message by sycholote
24/11/15, 07:02A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 11 Replies
- 9065 views
Last message by quebecois
25/06/15, 15:09A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 12 Replies
- 9606 views
Last message by I Citro
23/12/14, 19:34A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 180 guests
