Hello Lau
in terms of measured magnetism made with a compass
it gives nothing concrete in my case on the chevrolet doping
It was a question of measuring on the copper conduit where it leaves hot steam, on the reactor it is more difficult it is all surrounded by bodywork iron and high voltage system, the readings could not be significant.
So I voted no, I cannot say anything other than the measurement made on the copper conduit ...
But all kinds of measurements were made in 2003 on my 125cc experimental engine is other than with a compass, on a 100% panton one thing is sure the iron rod becomes magnetized, not very strong, the filings stick after when we take it out of the reactor, even if it is demagnetized with a demag for automotive parts, a simple start-up in the reactor and it is re-magnetized.
The magnetism of the rod is not as simple as that of a magnet, in the measurements that I made it is more similar to the magnetism that one meets in a carcass of transformer, but I have heard no one talk about this, but rather having questioned the test, i just stuck to these measurements.
But if you have the same signs as I do, a compass slightly requested to turn (it cannot start on its own to turn, like all 2-pole motors) should start to rotate as if it were clinging to a stream of synchronous motor.
It is easier to measure the field with the right instrument.
The magnetism measured if it serves as a function index
well done, but you don't have to create it with magnets to say it works. Like the reactor outlet temperature, or the vibration of the reactor when it starts to work, all these clues are there to guide us in our improvements.
but not goals to seek, what is needed is to improve the operation of the engine with treated water.
Electrification by flow in the water doped
- Former Oceano
- Moderator
- Registration: 04/06/05, 23:10
- x 1
I finally got it!
In fact the electrification is done by the INSIDE molecules the reactor that we made with our mind!
Jean-Claude VanDamme is right! Read, listen to what he says and think about Pantone.
"Inside of yourself, DEEP INSIDE, really inside, something invincible called LE SPIRIT, the spirit. We were built like that, we were made with LE SPIRIT. This is the straight line of the body, we think horizontal, 1h, 2h, 3h, 4h, we are INSECURE, people are afraid of time. How old are you, 40 years old? So when I say I'm going to die at 45, yeah, I don't give a damn about people's mouths! They did not understand, because the time, the seconds between you and me are seconds but for the oxygen which is a less compressed matter than your human body; 1 sconde is 100 seconds and the stone and the brick and cellars not what, it is made of enormous compression. You need the Black & Decker. But you take that pressure off and you become vertical like the mind. Everything falls, what's left alive? Molecules made of electricity because it moves. So there are the molecules which is made of arrows (we said that I was talking about the film, I'm sorry!) And then the electricity which is made at the very end of its layer of FEELING which is called LOVE and my FEELING is: I know you are listening to me carefully. But it's hard to hear things like that when he talks about the apple and the snake and ADAM and EVE but that is much more pausible questions. EINSTEIN's BIG-BANG THEORY, I MEAN, you put a molecule that you create, that it doesn't have, eh, it doesn't have the molecule, but we have it, we want to keep it, you see and he has this energy that made the BIG BANG and the universe has grown and that's the world, life is not complicated! "
The truth is really elsewhere
- camel1
- Pantone engine Researcher
- Registration: 29/01/05, 00:29
- x 1
Vandame!
And yes, ex océano! As Jean-Claude says, you must be AWARE
Otherwise, for electrification, I have an alternative to the compass, which will be more practical when it works, it is an induction coil placed on the outlet hose of the reactor, and connected to an oscilloscope.
I have already tried it, but it did not work, but I think that you have to damn amplify the signal to make it visible.
As soon as I have a moment, I make a small instrumentation amplifier, with a gain between 5000 and 10000, which will allow me to appreciate a signal of a few hundred nV (10-9V) ...
For my case, the remanent magnetization observed by some on their reactor rod is out of the question, since it is stainless steel ...
Finally, I follow this post carefully, because the electrification of the gas mixture is, in my opinion, a decisive factor concerning the efficiency of the assembly ...
A + + +
Michel
A + + +
Michel
We were on the brink, but we made a big step forward ...
- Similar topics
- Replies
- views
- Last message
- 2 Replies
- 6815 views
Last message by Christophe
View the latest post
19/08/06, 11:11A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 154 guests
