Pumping over sun
It seems a little fair to me.gerald222 wrote:thank you gaston very good proposal but too expensive for me by cons what do you think of my last post
40m pipe represent a significant loss of load, the flow may be ridiculous.
You need a pump capable of mounting at least 5 or 6 meters to have a reasonable flow (manufacturers always give the maximum height at zero flow).
Then a solar panel of a power (maximum there too) slightly higher than the power of the pump.
I think a pump like this one with an 40W panel could do the trick.
See all the posts by oli80, not the ram, but the paddle pumps that slowly turn along the river's current, even slow, and make the water rise in a serpentine even slowly to 1,2m, and even higher.
It could be a solution almost free, even with a current of a few cm / s.
Otherwise solar thermal pumping by evaporation condensation or air expansion is possible.
Example the fluidyne pump with a concentric mirror with parabola or cylindrical of the sun.
The same simple wind works.
It all depends on the flow requested on a day.
- Similar topics
- Replies
- views
- Last message
- 24 Replies
- 24420 views
Last message by Forhorse
View the latest post
08/03/21, 22:49A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 1 Replies
- 7052 views
Last message by Gaston
24/07/18, 14:14A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 22 Replies
- 23609 views
Last message by falord
05/04/12, 16:29A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 17 Replies
- 28013 views
Last message by oli 80
04/05/14, 16:28A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
Who is online ?
Users browsing this forum : No registered users and 105 guests
