Hello,
I am starting a first model of solar tracker.
For the moment, I would like to make it simple and enslave only a single axis in rotation to make an overall east-west tracking ... We will add a second axis then ...
The sensor is a set of 2 LEDs that produce an electrical voltage depending on their alignment with the sun. the 2 leds will have an angular spacing to define.
I have old memories of servo lessons where we did PID servo with calculations of transfer and company functions ...
I am crazy to see what I could swallow and not retain anything ... The TPs were so nothing concrete .... Finally it is another story ...
I can no longer bring my 'knowledge' back to my current need ...
With my current knowledge, I plan to use a small electronic development platform - ARDUINO - which allows me to position a servomotor at a given angle and which also allows me to measure the voltages across my 2 sensors.
I must therefore arrive at determining the position which gives a voltage equivalent to x% near on the 2 leds.
My algorithm will therefore be simple. Increase the angle if the voltage of led 1 is greater than led 2 and vice versa until the difference between the 2 voltages is within the tolerance which will be defined ...
Is it as simple as I expect or have I not seen certain difficulties?
If you have good ideas I am very interested ;-)
I should attack tomorrow at the reception of the much awaited ARDUINO ...
Question about angular servo
I also think it should be enough.
After if really necessary, the implementation of a PID is not excessively complicated. I did it for my wind turbine controller and despite never having studied the thing, I got there without any particular difficulty (it comes down to a few basic operations)
Doing everything in analog is good, and it's simpler. But if we want to add certain functions it quickly becomes a hassle (like going back to the east at the end of the day ...)
I've never tried Arduino, but I only hear good things about it, so it seems like a good base.
- Similar topics
- Replies
- views
- Last message
- 0 Replies
- 1891 views
Last message by Paul44650
View the latest post
08/06/23, 12:33A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 7 Replies
- 5784 views
Last message by izentrop
15/11/20, 00:46A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 0 Replies
- 3817 views
Last message by Bricolo07
29/12/16, 20:43A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 3 Replies
- 3398 views
Last message by xxx74
26/03/16, 08:49A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 6 Replies
- 17246 views
Last message by francis02
12/12/14, 11:36A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : gegyx and 196 guests
