For the ball ...
the crankset makes few turns in a minute 80 to 120 ... which provides little energy compared to a dynamo on the sidewall of the tire or a hub dynamo (dynamo SON for example) or a hub motor becoming generator on demand .
The ball would have to pedal harder to generate current in addition to pulling the chain.
When the generator (solar panel) is a "weight" ball, it brakes when starting, on a hill, but not on a flat once started or when going down.
With a hub motor, you can, thanks to the downhill regen, extend the range by 30% by managing well.
Lead batteries, forget it! weight ++ does not support strong recharges (solar, regen !!)
my kit comes from there:
www.declic-eco.fr
it's based on nine continent, but improved
Before I had a BionX ... well screwed up electronically, but dead ends on stuff well damage ... and system lock with electronics in engine + battery + console = big mess.
There it is nickel, the motor on one side which does nothing but turn, the battery which does nothing but supply / recover current, the controller which makes the 'nipples don’t electrify, and the Cycle Analyst to clamp, monitor consumption, speed ...
So to know the recharge time, you need:
- battery capacity (in Wh or Ah, in this case we do Ah * V to have Wh)
- generator power (100W peak panel, 75W good conditions, dynamo?)
and there if we consider that the energy input is regular, 75W in 1h = 75Wh
we divide capa battery by quantity of energy entered in 1 hour ... = recharge time.
For my 1000Wh battery, I need about 13h.
A driving day in the summer sun = 500 to 600Wh
In winter much much less! (lower angle, shorter days): 50Wh in one day?
In assistance, there are some who have tested a sail ... but you need the right angle, wind strength, not too much traffic (we make deviations), straight road. When there are the right conditions it works, but 95% of the time we transport the gear for nothing
(experienced by 2 tourdumondistes)
