Information for process Pantone
Water injection in thermal engines and the famous "pantone engine". General informations. Press clippings and videos. Understanding and scientific explanations on the injection of water into engines: ideas for assemblies, studies, physico-chemical analyzes.
User avatar
Moderator
Moderator
Registration: 13/02/07, 22:38
x 839
by Flytox » 16/02/11, 19:16
what do you mean by "good" steam ??
The "good" vapor, the one that "works" has not been characterized by anyone, so that we can try to reproduce it on any vehicle with a good chance of achieving it quickly. : Cry:
It can not be said with evidence that it is dry steam, or wet steam with such a quantity of water droplets of such diameter, that circulates in such a range of temperature and pressure with such a percentage of saturated air in water....
When you find the "right" parameters, empirically, it works. As soon as you leave it, there is no more effect on consumption. To really know what's going on, it would take fierce instrumentation ... not within the reach of an amateur.
So we hack gently by modifying the architecture of the assembly (GVI or bubbler, positioning of the inlets and outlets of the different fluids), the pipes (diameter length), the volumes of the different "chambers", the temperatures (insulators, size and length of certain components), pressures and flow rates (nozzles, compressors, or venturis), by varying the gas mixtures (air, water, steam, exhaust gases), by modifying the properties of the water (acidity, hardness, additives) ...
We end up arriving at the result more or less quickly and following many other parameters ....: Mrgreen:
The user manual is still to be written : Mrgreen:
Reason is the madness of the strongest. The reason for the less strong it is madness.
  • Similar topics
    Replies
    views
    Last message
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 142 guests
