Hello
Happy New Year everyone
I want to make a 4tps engine by replacing the connecting rod and the crankshaft with a hydraulic motor !!!
How? 'Or' What:
keep the cylinder head, the piston, the cylinder modified by the addition of a closing plate where two holes are drilled.
during TDC, the cylinder is filled with hydro transmission oil;
upon explosion, the piston descends, pushes the oil through an orifice in the lower cylinder plate, the oil under hardness feeds a hydraulic motor, the axis of this motor is the transmission shaft capable of providing various drives ( in particular the distribution); the oil used by the hydro motor returns to a pressurized cooler tank to supply the low cylinder and reassemble to compress the piston. of course the supply and return diurit are equipped with a non-return valve.
I hope I have been precise and understandable.
I expect from your reading, your opinions on the feasibility and the efficiency of this montage
orbs
Thermohydraulic motor !!!!!!
It is certainly possible, but we must see the losses by viscosity in the pipes and hoses and inelastic expansions which will not be negligible.
But certainly this has already been considered and tested, at least on hydraulic jacks and cranes, where a thermal compressor is used to pressurize the oil.
Oil machines are rather slow, powerful and precise and in principle not very compatible with rapid explosion in a piston where the inertia of the mass of oil behind will lose a lot of kinetic energy of the explosion in the form shock wave which will dissipate in the pipes elsewhere !!! (even a high proportion).
In small model on very small engine this can be experienced in hobby for cheap and identify the real difficulties !!
In slower Stirling engine it would be better ???
The idea is certainly to be deepened, at least in the bibliography, before testing.
There is idea .
But how do you think you manage to run this engine "regularly"? TDCs and PMBs could be "brutal" in deceleration (shock wave). Multi-cylinder compulsory to be able to accompany various accelerations, pressure reserve etc ...?
Reason is the madness of the strongest. The reason for the less strong it is madness.
- Similar topics
- Replies
- views
- Last message
- 25 Replies
- 2913 views
Last message by Macro
View the latest post
16/08/23, 21:35A subject posted in the forum : special motors, patents, fuel consumption reduction
- 17 Replies
- 11196 views
Last message by izentrop
07/09/20, 09:05A subject posted in the forum : special motors, patents, fuel consumption reduction
- 1 Replies
- 7707 views
Last message by Pascaltech
03/08/16, 10:11A subject posted in the forum : special motors, patents, fuel consumption reduction
- 1 Replies
- 8601 views
Last message by chatelot16
11/03/16, 20:29A subject posted in the forum : special motors, patents, fuel consumption reduction
- 9 Replies
- 8647 views
03/08/16, 10:22A subject posted in the forum : special motors, patents, fuel consumption reduction
Back to "Special motors, patents, fuel consumption reduction"
Who is online ?
Users browsing this forum : No registered users and 86 guests
