Hello,
I made my pantone engine. I oriented my mower to the north. I put some gasoline to start the mower. It worked for a few minutes and then it stopped. I have refueled several times. It starts but stops after a few seconds. I did not know how to run the mower.
How does the principle work? I put a little gasoline and then the rest takes over without needing to refill gasoline at each start after a few days
Thank you for your advice
Pantone engine problem
Hello Yougo
You should explain more clearly to us how you carried out your assembly and how you intend to make it work. So we can help you better.
For the orientation of the reactor, it is a huge rubbish.
Reason is the madness of the strongest. The reason for the less strong it is madness.
- Similar topics
- Replies
- views
- Last message
- 5 Replies
- 6559 views
Last message by Other
View the latest post
24/02/08, 03:13A subject posted in the forum : Water injection in engines: montages and experiments
- 4 Replies
- 4365 views
Last message by willoz
16/01/08, 17:53A subject posted in the forum : Water injection in engines: montages and experiments
- 4 Replies
- 5753 views
02/03/07, 03:48A subject posted in the forum : Water injection in engines: montages and experiments
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 220 guests
