Gillier Pantomists of all kinds ... Help!
For a Gillier Pantone engine, we can assume that during the few milliseconds of travel between the outlet of the reactor and the combustion chamber of the engine, we are in the presence of a mixture of dry vapor and a few myriads of tiny droplets of 'water. (evaporation is not instantaneous)
Having no idea how many and how big these droplets are, it would be interesting to find a way to at least change the droplet size, to find out if that size matters, and plays a role in performance. fuel saving / pollution.
One of the possible ways will be to modify the surface tension of the water which is introduced into the reactor, knowing that the characteristic size of the water drops depends on the capillary length.
Capillary length = square root of (Surface tension / (Density * acceleration of gravity))
This can be achieved by adding an emulsifier to water, for example.
Hence the following test with Carrouf "Brillant" dishwashing liquid of the stated composition: 5% amphoteric surfactants; 15-30% Anionic surfactants; also methylchloroisothiazolinone, benzisothiazolinone, methylisothiazolinone, perfumes.
Dishwashing liquid is diluted to 1% and heated in a pot on the stove. As long as the temperature of the pan does not exceed 100 ° (boiling) no problem, evaporation takes place without deposits.
After 100 ° quickly, a small yellowish foam forms then it quickly turns to black brown before 200 °. So it doesn't fit. The walls of the reactor rise from 300 to 500 ° or more and the water is no longer able to dissolve this deposit afterwards, so the reactor will end up clogging with the deposits.
We would therefore have to find a product which lowers the surface tension of the water, which can evaporate completely, and which of course would degrade during combustion without polluting ...
Come on, we need some suggestions !!
Gillier Pantone water droplets surface tension
Reason is the madness of the strongest. The reason for the less strong it is madness.
- Moderator
- x 11060
I do not think that we can "feel" anything without laboratory analyzes because on the road we will not have the necessary precision.
The size of the droplets can also be changed via the dimensions of the "famous" annular space, right?
The ph on the other hand has a significant influence on the ionization capacity and therefore the efficiency of doping. To read or reread:
https://www.econologie.com/explication-a ... -3323.html
https://www.econologie.com/explication-i ... -3522.html
These are docs that unfortunately went almost unnoticed when they were "published" ...
On a previous post, I put a link where we talk about the size of the water droplets. The medium is appreciably different (heavy fuel oil) but the laws which govern the micro explosions of the water droplets one certainly a possible transposition with a Gillier Pantone.
The lifespan of the droplets depends on their original size, among others.
http://paristech.bib.rilk.com/5429/01/T ... Tarlet.pdf
mirror: https://www.econologie.info/share/partag ... _Paris.pdf
On the contrary, I think the difference between a working and non-working Gillier Pantone is in the size and number of water droplets that arrive in the "right" place at the "right" time in the engine. By changing the size of the droplets through a change in surface tension, one can try a different installation without removing the torch. Finally, the field to be explored is rather vast.
Yes, I would like to have an inventory of all the parameters that govern the size of the drops.
Concurrent or complementary theory ... ???
Who is online ?
Users browsing this forum : No registered users and 215 guests
