PANTONE: GENERATION OF HIGH CURRENT of Argentina
Water injection in thermal engines and the famous "pantone engine". General informations. Press clippings and videos. Understanding and scientific explanations on the injection of water into engines: ideas for assemblies, studies, physico-chemical analyzes.
rodibruno
I understand econologic
Registration: 06/11/06, 22:19
x 6
by rodibruno » 10/02/10, 14:22
Friends:
This transcription is in Portuguese, is a forum that I’ve been involved in for years. He talks about the current generator (200 Amp.) With a Pantone reactor. Can anyone clarify this point or provide further elements?
Portuguese:
http://br.groups.yahoo.com/group/carro_ ... sage/13015
Traducción del portugués al francés Mostrar forma romanizada
It has been measured. It is one of 60 Pantone reactor anomalies.
Another anomaly is that the electrons are sucked in from a distance
up to 18 m of reactor. Not found in the literature why it
occur (which does not mean that it is not already explained). I do not
also found the explanation in the literature. Standardization of names
oxen, you speak the same language, there is a central bar, the inter pipe -
intermediate is dividing the gas and exhaust gas inlet
the external pipe containing exhaust gases. This measure
is between the bar and the middleman pipe, this pipe is the real one
heat exchanger, the cornerstone of the Pantone where everything happens.
I prefer to think of this anomaly as a capacitor, not
like a pile. When I entered (normative) Enter speak
gas at intake. At this point, the linear speed of
sucked the gas is 200 km / h and the tangential speed is a function
fins or paths before forced entry, maybe 50 km / h.
The first measurement of 10 A was used there. between the bar and the cannon
intermediaries THIS SITE. The second measurement of 200 A was made
between the central bar and the intermediate pipe that the location of
output, where the linear speed is 200 km / h but the speed
tangential up to 800 km / h. Who was the most electronegative or
potential for electropositive generation? It is not said. But it's expensive!
It is the intermediário.que barrel electropositive electrons supplying to
positive ions for its internal interface. And the central bar which is
electronegative by capturing the electrons that decay towards
center. This is how the canon intermediary foresees heat loss
electrons inside. As the barrel resets intermediate of its
electrons? Capture of their exhaust gases on their outer surface.
This is how the exhaust gases transfer heat to the average body.
When the exhaust gases are trying to neutralize the electrons?
The internal surface of the exhaust, the continuation of its external face.
When the outer face of the electrons from research exhaust? Make
environment! Porissa detected electron flow to
Pantone within a radius of up to 18 meters! A Faraday report
if not. It is an electronic money (because of the electrons and not
ions) decomposing from a distance of 18 m (in the experiment: 60 feet)
towards the eye of the hurricane, the center of the galaxy, the hole in the sink,
(similar examples from mother nature) of a message
Paul Pantone the Vortex group of Yahoo heat exchangers, he says
should not use yellow teflon tape to insulate the pipes, because
This low reactor efficiency. I mean (not stated) that the
the flow of electrons produced by the springs of the central bar and resets
the absence of the intermediate tube. I felt the stench of disinformation!
These pin inlays centralize the bar too
smell of misinformation. They are short to the pipe of intermediaries who
lower the efficiency of the cross-flow of electrons and the tip
capacity which is formed, which generates 200 A (or more,
without the shorts) However, anything that hinders cross circulation
prevents heat transfer by loss of electrons (when a
atom loses an electron there "cool". Then the heat becomes
transferred only by conduction and turns Petrobras cracking and
No of transmutation of matter. An experience that is likely to
I never do (US $), but it would be spectacular to make a reactor
vertical passing through the center of a doped water tank
NaOH or KOH (Read Up H3O + and OH-in the net) I can't
not imagine what HHO could produce, since the
electrons sucking the environment would necessarily
cross inside the water. I can not imagine
which would connect to the outside of the tank with a
Exit point of the bar as the accused 200. Just as it
imagine the power of the engine that could have let go
This intensity, in the center of a Faraday disc, so yes,
collects the edges of the conduct of the intermediate ballot. What
know is that in an internal combustion engine more than 1/3 of power
becomes heat loss. What would you do if someone
said: I provide between 10 and 15 kW free for any use.
What would they do?
The Internet always has 50% and 50% uninformed information
tion. It is up to us to seek the essence, because, the interests
the same information to make yourself known and
sell their fish, misinformation to keep the fish just for you. this is
the case of Pantone. Porissa Spoken to Check Your Spoken Truths
absolute.
Moderator
Moderator
Registration: 10/02/03, 14:06
x 11060
by Christophe » 10/02/10, 17:57
When I read 200A, I think it's bullshit ... or that the guy can't measure ...
: Cheesy: :?
User avatar
Moderator
Moderator
Registration: 13/02/07, 22:38
x 839
by Flytox » 10/02/10, 22:46
Hello rudibruno
Sorry but this Portuguese / French translation is completely incomprehensible .... : Cry: : Mrgreen:
Reason is the madness of the strongest. The reason for the less strong it is madness.
rodibruno
x 6
by rodibruno » 11/02/10, 02:02
Flytox wrote:Hello rudibruno
Dear friends,
Leo and I speak Portuguese quite well, unfortunately not the same thing happens with French ... so I put the link in the forum for what you translate pudierasis.
There will not be measured highly defatted cocoa, but for their comments on various issues, seems to have solid knowledge of what it is talking about, the data group exchanger vortex bag Yahoo, and measurements have been made by what I thought I understood ...
I did not see the other members of the group, those who have more experience of discrediting him.
I think it's worth a little research that!
If indeed we are faced with a huge source of energy !! ... and free!
Greetings
  • Similar topics
    Replies
    views
    Last message
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 103 guests
