Hello and best wishes in the New Year!
Here, I would like, in the continuation of the studies on the frying oil burner, to propose to modify an oil stove in oil stove!
I firmly believe that this is achievable, at low cost and without too much trouble, knowing that the diffusion part will adapt
the trick would be to preheat, burn and regulate the oil supply
I know that there are some who have made changes to the oil stoves, I would rather make it on a mobile device like the oil stove
the original device sometimes smells bad because of the different quality of oil
I carried out tests by mixing 50% petroleum and 50% oil without changing anything and it doesn't work, even when decreasing to 20%.
I look forward to your opinions, and so start the topic!
thank you all
Modified oil stove in heating vegetable oil
- bleusideral
- Éconologue good!
- Registration: 14/02/09, 15:35
- x 4
A gesture more econological econological a gesture and it is the planet that will suffer more!
- bleusideral
- Éconologue good!
- x 4
Hello
The principle is relatively simple
the petroleum fuel is absorbed by the capillarity of the low tank on a higher wick and it is set on fire (in this case an electric igniter) the flame is made through a diffuser consisting of a perforated cylinder and a glass on the periphery as old kerosene lamps
oil, it has difficulty being absorbed by capillarity, especially when cold
for the smells, I don't think that we feel much if there is no unburnt, but that remains to be seen
we could maybe be inspired by justemilieu's kitchen burner, I'm waiting to know what he thinks about it
as for oil, indeed, it's not great sometimes, smells, and I don't know what you breathe when you burn! and oil is expensive too !!
- Similar topics
- Replies
- views
- Last message
- 6 Replies
- 30771 views
Last message by MichelM
View the latest post
04/12/05, 15:17A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 284 guests
