Hello,
dan [img] s the goal of transforming it (if possible) into generator I bought of occasion an ARDAM engine.
Features on the engine label:
WORD ASYN 1-50 Hz
V220 CLE Rot Cage
TYPE 300 CII / EGXI
WATT 180 60
Rpm 2750 41a
A 3 1
cond
µF 55 9
cond
V 275 400
Service S1 S1
2 red wires and 2 black wires arrive respectively at what seems to be 2 capacitors
4 wires (white brown green blue) arrive at a domino
Inside, at the "bottom" of the engine a "fork" connected to a wire
is in contact with the rotor through a large washer (collector?) secured to the rotor.
When disassembling neither the rotor nor the stator are magnetized (do you have to supply the TWO with electricity to induce magnetism? Or is it enough to supply only the rotor, the stator integral with the casing being made up of winding).
When I turn the rotor no "juice" comes out of the 4 wires of the domino, on the other hand something seems to "stick" to the interior and makes a "click" at the desceleration.
In short what is the use of this type of engine? is it possible to transform it into a generator? How? 'Or' What?.
I tried to take photos but they are too large or corrupt! (I will try again)
Thank you in advance to the econologists who touch on electricity and are already very solicited
What do you think this engine is?
good evening fatfreddy
single-phase motor with centrifugal contact, 1 starting condo and one permanent condo.
1 start winding and a phase shift winding
very difficult to adapt to make a generator
and considering the powerful 180 w I don't really see what you can do with it
please
ok thank you for your answers I bought this thing really at random
(2 euros) if you still have the patience to answer me can you tell me if I risk to burn something by feeding the domonino of the 4 wires a little "off the cuff".
You understood that I knew nothing about electricity but in
browsing the forums I deduce that there are (can be) 2 wires to be supplied with 220v to create the magnetism in the rotor (through the "fork" in contact with the rotor) and the other two for the power supply no ???
Re: thanks
fatfreddy wrote:ok thank you for your answers I bought this thing really at random
fatfreddy
Don't waste time with this engine!
Even if you succeed in making a generator with it, the output will be so rotten that you will abandon it.
Find a brush motor that will run at least, even if the performance is not top.
What do you plan to do with a gen?
A wind turbine?
Stepping behind sometimes can strengthen friendship.
Criticism is good if added to some compliments.
Alain
Alain
- Similar topics
- Replies
- views
- Last message
- 4 Replies
- 5491 views
Last message by Kylie7
View the latest post
27/05/20, 10:22A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 9 Replies
- 4663 views
Last message by chatelot16
23/03/13, 13:05A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 1 Replies
- 3011 views
Last message by recyclinage
26/04/10, 12:13A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 3 Replies
- 3164 views
Last message by Christophe
08/12/09, 22:31A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 13 Replies
- 19653 views
Last message by hic
10/08/15, 20:05A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 159 guests
