Hello
I installed my pantone system on my bx I have not yet measured consumption.
I have problems keeping my boiler level constant
I use an oil stove fuel float but I have problems with the floats which does not hold (fills with water) I try a polystyrene flush float but after 2 days more float (disintegrate)
I am looking for an electric level detector which can resist temperature (+ 85 °) and vibrations
Who can give me a solution (econology do you have a solution?)
please
constant level for boiler
- I posted 500 messages!
- Registration: 31/03/04, 07:37
Hello,
I plan to show a reactor on my xantia td.
To control the level and consumption I think of using the system that Citron has been mounting for millennia on its LHM vessels. This allows a visual level check and it closes a contact when the level is too low. Coupled with a fuel tank it gives an autonomous system, the heating can be done afterwards in the bubbler, suddenly no problem of floats melting.
A CX is Bo ... But it's rusty !!!
- rezut
- I understand econologic
- Registration: 01/12/04, 14:58
- x 2
Hello
very good idea the lhm vase on the other hand no maximum level so it would be necessary to couple a tempo relay to the low level contact which will let flow a little water via a windshield washer pump (for example) for a time determine and turn and play
and why couple a carburetor (there is no longer any need)
for the pantone you will put it or (I put mine in the exhaust pipe which I redid entirely but after the first full I did not notice a drop in consumption)
may be due to lack of cross flow
I try to attach a photo of my montage
constant level tank
Need help !!!
I want to buy "constant level tank" same in the pictures, anyone can help me? It made from brass.
Many thanks!
Schwinn
THAILAND
Many thanks!
Schwinn
THAILAND
I'm from THAILAND
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 188 guests
