Outside insulation
Renewable energies except solar electric or thermal (seeforums dedicated below): wind turbines, energy from the sea, hydraulic and hydroelectricity, biomass, biogas, deep geothermal energy ...
killkiller
I discovered econologic
Registration: 08/11/09, 22:16
Outside insulation
by killkiller » 11/11/09, 18:57
I inquired about the exterior insulation, I would like to opt for this type of insulation, but I was told that we could see the location of the insulation panels on the plaster.
The insulation must stop at 15cm from the ground? Does this change the exterior appearance by creating an offset on the ground?
aerialcastor
Registration: 10/05/09, 16:39
x 21
Re: Exterior insulation
by aerialcastor » 11/11/09, 22:42
killkiller wrote:I inquired about the exterior insulation, I would like to opt for this type of insulation, but I was told that we could see the location of the insulation panels on the plaster.
Never heard of it. In any case, it is clearly that the facade maker has a bad job. There are lots of achievements in France and especially abroad.
Killkiller wrote:The insulation must stop at 15cm from the ground? Does this change the exterior appearance by creating an offset on the ground?
No, on the contrary, the insulation must go down along the base wall to avoid a thermal bridge. This insulation must be done with a material that supports humidity, therefore PU, PSe or better cork (but €€€).
  • Similar topics
    Replies
    views
    Last message
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 142 guests
