bsr flytox, I would not encroach on anyone's subject, don't worry, by the way, I'm not going to drag on here or on others forum, there are always the same things there, I wish you that happiness, I also had a lot when I got interested in that loan.
good luck to all of you, it's always better than going to the bistro !!
michel
pantone doping Mercedes MB100 (meme that 220d)
Hello
I weld my montages with Argon TIG
the flow meter on an old diesel indirect injection there is a return
some injectors have a measurement system on an injector (on Peugeot),
It is not the cost of diesel but time passes on the road which is long
measuring a difference between 25% and 30% requires as much rigor as measuring a small gain of 5%.
Could you elaborate for people besides because I do not understand too much .. But I would like to know if it is not intrusive, have you removed the system in full from your cars or else you continue to drive without making any measurements . (which happens to me often)
Because after a few years of use when it stabilizes or no improvement on the rise, the tendency is that you put water in the tank, you roll and you no longer measure anything.
The measurements you make just on long journeys or only after you make a small modification.
When you have a system that works you are not tempted to replace everything with something else, you just make small changes around
I understand that at the beginning we are more enthusiastic and when we reach a ceiling, we are less persistent.
I ask myself the question how many who had an operational system the removal of their vehicle thereafter ??
pacificso wrote:bsr, andré, i think,
especially do not waste your money in `` magic '' pasta of cold welding and others !! if you don't have it at home, find a guard not too far away who will gladly make your soldering, especially if everything is ready to weld !!
michel
Why don't you put a flow meter out of your tank?
michel
WHO CHANGED MY JOB TITLE? (I have an MB100)
Hello to everybody,
well I have a small change of program, in order to avoid having to change a part which could be expensive if it were to break by dilation, I fall back on the traditional transformation of the exhaust pipe for the realization of the reactor (but I still think that I will do the assembly that I had planned, the day when I will recover an exhaust manifold from MB100)
Actually I also heard about that I will study the question
a+rom1
Hello to everybody,
On your shema you do not isolate the rod and the tube of the reactor ...
a+rom1
Hello Andrew,
c ok for the expansion but if I let it slide that you think to seal (and also for the vibrations) with the paste that flytox advises me above? (that's a question for later as I explained the other day.)
By cons by looking at your different reactors I saw that they were more or less streamlined is it really necessary? because I was offered to spin my reactor rod.
And what do you think of isolating the reactor, a friend told me to do it with porcelain?
a+rom1
a+rom1
Hello
If you absolutely want to put it in the cast iron you make a precise adjusted hole there is little leakage (the reactor tube welded in one place.
For the rod which is isolated or not that does not change much (in my case it the rod of retained is welded (I was tanner to hear the rod vibrated at the slowed down)
Only forget a porcelain or other support if it breaks the engine downstream and in a diesel the piston passes very close to the cylinder head
The reactor requires nothing in particular, a rod of approximately 150mm an air gap of 1mm or more is not a few tenths that will change something. The rod is covered with an insulating layer in use. (takes stainless steel material you will not return later to the rod reactor)
In my case for water doping
the improvements came just by modifying the way of making the vapor which enters the reactor it is the only place where I made changes, that it is GV, bubbler, injection, it is at this place that happens improvements not in the reactor
You can play on the air, the steam, the amount of water
ROM1 wrote:c ok for the expansion but if I let it slide that you think to seal (and also for the vibrations) with dough flytox advise me above? (that's a question for later as I explained the other day.)
Pattex type paste is good for not too high temperatures (like 220 ° max) but not for exhaust near the cylinder head which goes from 90 to 750 °. it's a resin, not metal.
But as André tells you, if your reactor passes with very little clearance the wall of the exhaust (0 to 2/100 mm) on a very clean surface (machined) with a good surface condition, it's good, that works and it will not crack any more and the leaks will be negligible! If you put too many games, you will have noise, leaks and maybe even cracks
Reason is the madness of the strongest. The reason for the less strong it is madness.
May the force be with you....
Good luck
Good luck
- Similar topics
- Replies
- views
- Last message
- 14 Replies
- 8293 views
Last message by GuyGadeboisTheBack
View the latest post
22/11/21, 11:38A subject posted in the forum : Water injection in engines: montages and experiments
- 6 Replies
- 9052 views
Last message by kestjc
11/11/21, 17:39A subject posted in the forum : Water injection in engines: montages and experiments
- 6 Replies
- 8958 views
Last message by denis
08/07/19, 15:09A subject posted in the forum : Water injection in engines: montages and experiments
- 19 Replies
- 22106 views
Last message by Flytox
14/12/17, 23:04A subject posted in the forum : Water injection in engines: montages and experiments
- 51 Replies
- 65177 views
Last message by chris59
19/08/13, 12:02A subject posted in the forum : Water injection in engines: montages and experiments
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 226 guests
