OVER-UNIT GENERATORS
- Moderator
- x 10973
For Patou. Hello. Accidentally I caused a reflux of the field of a magnet by preparing a repair on a machine, it seems naive and simple but it works. On the drawing we see on image 1 an electro magnet which works in static (at the bottom behind the core there is an intercalated magnet) and on the electromagnet there is a WASHER with a threaded rod which is used for an operation x on a machine. At rest it is the WASHER which closes the circuit attracted by the magnet and without any tension obviously. Image 2 if I put 20 volts on the coil while respecting the polarity I create a North pole which repels the flux of the magnet well and on the other side of the coil I create a flow South which identical to the flow of the cylinder of mild steel does not cause any more attraction of the WASHER (no flow to close) On the other hand by curiosity I increased the tension (image 3) and to 24 volts I transforms the whole into a real electromagnet which produces a much superior flux laughing at that of the magnet (the field of the magnet is completely annihilated under the field produced by the COIL which becomes the main part to produce the field allowing the sticking of the WASHER) BUT THAT ONLY AT A VOLTAGE OF 24 VOLTS (this is not what is given by the manufacturer; below (so below 20 volts) it is the magnet which closes the circuit at rest. So a very simple experience demonstrates that one of the secrets the operation of an electromagnetic generator resides well in the pulse coils (only for images 1 and 2) Unless you are working on frequencies of several kHz, you need a good calculation for coils in 50 Hz and therefore a lot of turns. Friendships JC forum If it's possible :
- Moderator
- x 10973
Well ... fully agree for that, just give the links to it forum and the On Unit test page of the site .... but generally I am still quite pessimistic in the interest of people (just look at the reactions on the forum futura sciences to be convinced)
Re: FREE ELECTRICITY HERE ...
I just found this video.
http://video.google.com/videoplay?docid ... 0742&hl=fr
can you find explanations (in french)
patou
patou
MessagePosted on: Fri 23 Oct 2009, 07:53 Post subject:
Re: is the calculation right?
patou wrote:
I found this on a very old system D.
tell me what you think?
https://www.econologie.info/share/partag ... E9TI4i.jpg
receive my thanks.
patou
something else :
http://www.youtube.com/watch?v=7yoM4Qjm ... re=related
this video I need the plane of the electronic circuit.
_on the forum following:
http://66.196.80.202/babelfish/translat ... -poli.html
I can see Appendices pictures how I can do because to see these images you have to register but it does not work.
Thank you
patou
patou
receive my thanks.
patou
something else :
Thank you
patou
Go back to "Innovations, inventions, patents and ideas for sustainable development"
Who is online ?
Users browsing this forum : No registered users and 125 guests
