Geothermal energy, not convinced by the air / water cap
Renewable energies except solar electric or thermal (seeforums dedicated below): wind turbines, energy from the sea, hydraulic and hydroelectricity, biomass, biogas, deep geothermal energy ...
User avatar
loop
Registration: 03/10/07, 06:33
by loop » 18/02/08, 21:48
Reply to Christophe
1) Well the heaters on radiators is also shit, right?
For air- PACs, there are two phenomena which combine when it is cold:
The efficiency drops while the temperature to be supplied by the radiators should increase. The conclusion is obvious.
Otherwise, failing to be ecological (due to electricity production), water-water heat pumps are economical to operate. As for investment, it is something else. Some people are satisfied with it, others not. Difficult to generalize.
but in renovation putting a heated floor is not ideal ... but there are LV radiators ...
Yes I have been talking about it for a while and we must not dream, the majority of homes are in this case and nobody is going to invest in LV on an existing installation unless simply increasing the number of radiators. It's not win .
People who ask me for information on solar (I am far from being a specialist because I do not have an installation), are generally in the same case as me (described above)
I speak to them about isolation at first and then I go to practical experience:
Reduce the temperature of the water circulating in the radiators to the extreme (40 ° or better 30 °). If we manage to maintain a constant temperature despite the cold outside, this is a good sign
Otherwise, isolate, further isolate. Remember to cut the thermal bridge at the base of the exterior walls by digging a deepest possible trench (basically frost-free) because old dwellings (but also modern ones) have a cold floor because of this.
The design of a solar installation, there it is serious and indeed, the secret is the buffer. For the moment I have not found the optimal solution but I am looking before going any further.
nmujdzic
I discovered econologic
Registration: 15/02/08, 15:49
by nmujdzic » 19/02/08, 10:14
With an average efficiency heat pump 3, the electricity consumption will be 20000 / 3 = 6666 kWh electric
Consequently, the EDF budget to be forecast will be around 600 euros, without subscription, or 100 euros per month.
The savings will be 2000x0.08 = 1500 - 600 = 900 euros per year
The profitability of a heat pump at 15000 Euros (installed and sold by a professional) will be reached after 17 years
I allow myself to resume the calculation in my case:
PAC at 7000 euros
saving 900 euros / month compared to fuel oil.
50% tax credit on the 7000 euros = 3500 euros
Either a profitability reached after 4 years.
User avatar
I Citro
Registration: 08/03/06, 13:26
x 11
by I Citro » 21/10/09, 23:17
PAC at 7000 euros
I come across this subject and I jump. : Shock:
nmujdzic could he share with us his feedback since his response dates back more than a year ... :?:
Furthermore, I cannot leave the above erroneous calculations without making a correction ...
6666 KWh of electricity represents around 700 € including subscription, ie 800 € annual savings and almost 9 years before "amortization".
I note in passing, that the tax credit is no more than 50% on PAC ... :|
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : Google Adsense [Bot] and 275 guests
