Well, we talk about acting on fuel, not on the junk?
you should re-try 0.5%
Save 32% Fuel 2 Engines Time With Acetone
- I understand econologic
- Registration: 26/10/05, 19:19
- x 1
Good evening everyone,
Not really in the subject, but to inform (André in particular),
the uncured polyester is cleaned with white vinegar.
Much less expensive and polluting.
It is true that it is poison this product, if you sniff too much in a place not ventilated enough, as I use 4litres to wash aluminum before painting, brushes for polyester ect ..
Hello
Thanks for the tip I will try
For acetone in the two-stroke, it was on these engines that I had the best results (Lawn boy lawn mower)
I walked with 1% acetone and klotz oil, synthetic castor oil was almost 50% more than without acetone.
The problems I encountered, after having increased the acetone dose again the needle of the carburetor rubber broke
I replaced the black rubber point needle by the new red tip, the ones that are more suitable for methanol fuel
A two-stroke engine when you deplete it also depletes the lubrication, microlights all know that a long descent to idle and you get the engine.
If you want to impoverish it like snowmobile riders, walk with special oil at low% .. in both times there is oil and oil ..
chevesne51 wrote:Good evening everyone,
Not really in the subject, but to inform (André in particular),It is true that it is poison this product, if you sniff too much in a place not ventilated enough, as I use 4litres to wash aluminum before painting, brushes for polyester ect ..
- Similar topics
- Replies
- views
- Last message
- 72 Replies
- 54412 views
Last message by nikolaj
View the latest post
09/10/23, 09:11A subject posted in the forum : special motors, patents, fuel consumption reduction
- 32 Replies
- 44307 views
Last message by POISSONIST
17/08/08, 18:03A subject posted in the forum : special motors, patents, fuel consumption reduction
- 44 Replies
- 23104 views
Last message by jonule
21/02/08, 13:36A subject posted in the forum : special motors, patents, fuel consumption reduction
- 73 Replies
- 68544 views
Last message by gilgamesh
20/10/08, 19:54A subject posted in the forum : special motors, patents, fuel consumption reduction
Back to "Special motors, patents, fuel consumption reduction"
Who is online ?
Users browsing this forum : No registered users and 227 guests
