Hello everybody
Completely new to the Pantone system, I was wondering if this process could possibly be adapted to the aeronautical industry ??
Because pollution issue, they are the champions ... Several tons of CO² for a single long haul trip !!!
Merki to you !!
@ soon
Pantone and aviation ??
- I learn econologic
- Registration: 15/12/05, 14:20
Hello
l had a very conservative world, except in wartime
this is fine technology and we try everything
In peacetime aviation before putting anything on an airplane it must prove itself by x and when has the pollution
this is not a convincing argument, autonomy comes before.
To give you an idea how conservative they are
The piston engines on aircraft have technology from the 1945 years. (truck engines)
Before 1970 legally the engines could only run on non-detergent Mongolian mineral oil
in the 80 years legally we used multigrade detergent oil
In the 90 years, you can legally use semi synthetic oil.
I pass you for everything else but in aviation, this must have proven itself on cars for a long time.
So in fact, the answer to my question would be according to you:
- Yes it is possible to optimize aircraft engines with a system inspired by Pantone ...
- But the Pantone system must first prove itself on car engines for 2 generations before being adapted to aeronautics ...
- except maybe in wartime ... which I don't want of course
Well, it's not very encouraging !!
Merki of your answer
- Asgard bone tyr
- My R21 Pantone on TF1 :)
- Registration: 06/02/05, 18:21
- x 1
Hello Asgard
As for the BF-109 Gustav
the injection of water into the Daimler V12, the reason was not for the economy like us, the role of water was to be able
use the compressor without auto-ignition and increase the power in combat, and for good reason the spits had inflate their Rols R engine.
the disadvantage you have to take on water mixed with alcohol
it's cold at 15000 feet.
Moreover the fuel of the Germans was weaker in octane than that of the Americans (quite simply because Europe did not know how to recognize the researches of a French engineer who in the years 20 had developed a system of Cracking of petroleum who gave fuel at high octane, he is going to exploit his ideas in the USA)
Go see on Christophe's notes there is a paragraph on this subject.
If you want information about the BF-109 I have a vast documentation on this plane, which was of a simplicity of construction.
- Moderator
- x 11060
André's explanation is perfectly correct and here is the article in question: https://www.econologie.com/par-daimler-b ... es-84.html
Kevin, I put you a special rank (TF1 + develop) as well as a new avatar ... because I think I deleted yours without doing it on purpose IF you don't like, put it in another recess ...
- Similar topics
- Replies
- views
- Last message
- 0 Replies
- 6863 views
Last message by Christophe
View the latest post
14/06/16, 23:04A subject posted in the forum : Water injection in heat engines: information and explanations
- 22 Replies
- 33206 views
Last message by Flytox
08/12/13, 11:57A subject posted in the forum : Water injection in heat engines: information and explanations
- 0 Replies
- 11660 views
Last message by carmelo42
03/05/13, 09:33A subject posted in the forum : Water injection in heat engines: information and explanations
- 13 Replies
- 29577 views
22/03/16, 23:19A subject posted in the forum : Water injection in heat engines: information and explanations
- 5 Replies
- 19149 views
24/10/12, 19:39A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 146 guests
