install a Pantone on a vw transport
Edits and changes to engines, experiences, findings and ideas.
reefbreak
I discovered econologic
Registration: 10/01/06, 16:31
by reefbreak » 10/01/06, 16:38
Hi everybody
I want to equip my transporter (1600 ct engine) with a pantone reactor
I already have a lot of info but I'm missing one of the most crucial!
How to calculate the reactor dimensions while knowing that the spaces between the tubes and the rod must not exceed 2 mm
So how do you know the length and the required daimeter?
Merci de votre réponse
Eric
User avatar
krissg29
I understand econologic
Registration: 07/11/04, 21:26
by krissg29 » 10/01/06, 19:25
Hi Eric
go see Adrien's subjects
he doped with water on a wetsuit
it's almost the same engine as the 1600 CT
https://www.econologie.com/forums/moteur-pan ... vt755.html
It should not be confused and ingenious engineer
Other
Pantone engine Researcher
Registration: 17/03/05, 02:35
x 12
by Other » 10/01/06, 19:36
Hello Kriss
Did you take a sabbatical year? or other, you are caught in other concerns of life (I speak for the injection on your WV)
it is difficult to find the time to do everything, we have to live through our DIY.
In my case it is the tests that I find long it eats a large part of my time ...
User avatar
Asgard bone tyr
My R21 Pantone on TF1 :)
Registration: 06/02/05, 18:21
by Asgard bone tyr » 10/01/06, 19:56
If we did them together the tests will take less time !!!
I take this opportunity to re re re re re make my offer to which nobody responded to by christophe and pitmix !!!
Other
x 12
by Other » 10/01/06, 21:23
Hello Asgard,
The problem in the climate that I live the tests will only be validated in the month of May, currently I am basing myself against the temperature and the insulation of the rooms in summer it gets too hot, in winter I only make short trips.
To do tests it takes a system that works all the time
often times in fact changes and the cause is elsewhere,
I fully agree that we must talk to each other, and I believe that I do my share, often there are unhappy experiences to which I do not speak about it would only confuse the forum , only when a guy talks about a project we can intervene to tell him that we have not succeeded in this or that montage.
When I give consumption figures it is always done on a journey of more than 200km and in summer, because in winter even by heating the air and everything I do not arrive at the figures for summer ...
User avatar
krissg29
by krissg29 » 10/01/06, 21:28
hi Andrew
It is true that I did not do much on the cox or on the pantone this year (2005), except to follow the forum and some small non-pmc experiences.
You still have to take care of the family and the house from time to time
I will try to improve in 2006 (a little less theory and a little more practice).
And for the tests with Asgard and the others, maybe with the Econology association it will be easier to organize?
User avatar
snono
I learn econologic
I learn econologic
Registration: 22/11/04, 09:37
by snono » 11/01/06, 10:59
No better for me in 2005.
I wish us all a happy new year 2006
with lots of little pantones and other energetic exoticisms.
  • Similar topics
    Replies
    views
    Last message
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 118 guests
