grandpa Stone wrote:I put a propeller 24 / 20 and it turns to 1400 see 1500tr / mn for 8km and + - 1600 1800tr / mn for 10km / h
24 / 20 means what exactly, in metric dimensions
you could have even put an even bigger one to run your engine at 1100 rpm for 10 km / h to consume less
pity that there is not a gearbox, you could have tried different report and note the consumption for each speed while staying at 10 km / h
at most the engine is loaded, at least it will consume in relation to the work produced
in your case, it is necessary that it turns as slowly as possible while making you advance to your 10 km / h
bolt
