I am not a hydraulic engineer, but a hydrobiologist.vinio wrote:[...] Bucheron, if you share an Excel file like this it is imperative to put a legend on the definitions of your formulas. What is turbine flow ??
Unless you are a hydraulic engineer, there is little chance that your Excel spreadsheet will be used.
In addition, this only applies to a certain type of turbine or all ??
I made this little file for a friend, looking right to left and with my limited knowledge of hydraulics.
Everything in the formulas is explained to understand what it is. It is not an educational document.
If turbine flow doesn't make you think of the amount of liquid going through the turbine, I can't explain it any more, sorry.
With a little more details, but the online version is enough to rough it up.Christophe wrote:[...]
For Bucheron .xls, it gives roughly the same thing as the online version ...
