You're welcome KrissG29;)
The origin of Zenoah engines powered by this type of fuel is used for brush cutters, hedge trimmers, etc. all in 2T, and therefore the speed is not stationary and is subject to both high speed but also high speed high load therefore a strong Air / Fuel ratio regulation.
The advantage also of this type of carburetor is that it is designed to rotate with a petrol / oil mixture, which makes the density more important, therefore different design ....
In a way, this is the best way I have found to run a diesel heating engine without all the constraints that we encounter with a Dell'Orto SHA type carburetor.
This is the reason for this choice.
Voila voilouuu
JOE
First Test PMC-GEET Pantone
- tigrou_838
- I posted 500 messages!
- Registration: 20/10/04, 11:25
: rolleyes: hello everyone, for information on carbs, go for a ride in a small model chop, you have carbs for all cylinders and powers, from the smallest to the largest, more without tank and better designed than the others, moped and cars (at least technically) you can put one to supply the reactor with water vaporization, and another in the reactor and the engine, depending on the positioning it will cause depression that need. (therefore aspiration)
ps; it exists in wood or drawer, you see depending on the configuration of your assembly
;) good luck B)
;) good luck B)
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 136 guests
