hello to all, coming to meet you and register at the same time !!!!
it is not easy to be well informed between the real innovations and ...................... the commercial sense of the sellers
I therefore have an insert that gives me satisfaction, however, the price of wood on the Mayenne as well as the handling makes me ask myself the following question: currently 60 € per dry stere 2 years !!!!
are compressed or compressed logs of wood effective and / or profitable? ecological impact?
info is scarce on the web so I'm a bit lacking.
thank you for all your advice when using my insert and / or using these famous compressed logs
Sincerely
Philippe
Wood heating in Mayenne: pellets or compressed logs?
- Philippe Schutt
- Registration: 25/12/05, 18:03
- x 33
Compressed logs are very dry (<10%), and give combustion as good as very dry wood (3-4 years). On the other hand, they are more expensive and be careful with storage which can make them regain humidity.
On the other hand, I saw that there are logs "night", slow combustion. I doubt the cleanliness of this combustion there.
what is your insert?
Thank you for your reply
voila, my insert at about fifteen years', it is a 10KW godin, with a nozzle to diffuse the heat in the corridor and annually I burn between 3 and 4 cords, according to the winters. because of my irregular schedules, I am forced to leave a background of electric storage heating which gives me satisfaction!
it is true that compressed logs interest me but how to know if the ration cost / size / efficiency is at least good? the literature on the subject is scarce, apart from the commercial links that are worth ............................. what exactly? ?????
merci de votre aide
Philippe
merci de votre aide
Philippe
- Moderator
- x 11044
Re: thank you for your reply
robi53 wrote:it is true that compressed logs interest me but how to know if the ration cost / size / efficiency is at least good? the literature on the subject is scarce, apart from the commercial links that are worth ............................. what exactly? ?????
They call me ????
- Moderator
- x 11044
Well, I can say everything except ... about the prices ... which vary greatly depending on the location and the producers.
I saw that in France compressed buchettes could be more expensive than pellets ...
In terms of use, I think it's the best compared to wood and pellets (we tested the 3) because:
a) there are no disadvantages of woodworking (no splitting, no bark lying around everywhere)
b) it burns in "everything" not worth a pellet stove (which only burns pellets)
c) it almost does not make ash
d) it's always dry
e) it heats up very quickly
The only drawback is that:
a) it burns (at equivalent volume) faster than a log
b) it can make a little dust when strongly handled (shock)
d) it's always dry
- Philippe Schutt
- x 33
THANK YOU SO MUCH FOR YOUR ANSWERS
and pellets, can we put some in the chimney, but without risk?
advantage / disadvantages if feasible?
it's great internet, thank you for your help and glad to know you
Long live awareness of a problem burning the environment but that the subject is vast and the choices uncertain?
good to you
Philippe
good to you
Philippe
- Moderator
- x 11044
Well, we tested: the pellets do not burn well "alone" in a fireplace ... mixed with something else, yes but only no, it is the disaster!
You have to ventilate / aerate a lot more than with wood or logs ... so you have to add a "room" in the stove, like a "perforated aerator tube"
I even made a subject to try to modify our stove but I did not reach the end of the experience!
Everything is here: https://www.econologie.com/forums/bruler-des ... t6923.html
Beyond 2 cm deep, the pellets remain intact (thermal insulation, not enough O2 ...) when the stove is on ...
- Philippe Schutt
- x 33
Christophe doesn't like to split wood, and I know guys who go out to make their wood with the same pleasure as others who go fishing. (not me)
So it's up to you to see according to your tastes and your means.
there are baskets to burn the pellets in a fireplace. But I do not see the interest, as well take pressed logs.
- Similar topics
- Replies
- views
- Last message
- 1 Replies
- 4694 views
Last message by Philippe Schutt
View the latest post
05/04/14, 19:50A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 25 Replies
- 15633 views
Last message by chatelot16
19/12/12, 10:42A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 66 Replies
- 26314 views
18/10/12, 14:17A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 33 Replies
- 25217 views
Last message by sicetaitsimple
20/05/23, 21:10A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 72 Replies
- 32374 views
Last message by dodo
06/03/11, 21:57A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 365 guests
