Hello
I have been using rainwater for a year to supply my toilets and my washing machine.
I filter at 90 microns, I clean my filter once a month. It gets stuck with an ocher film.
I find this film in the channels after the filter. Will there be any particular consequences to this problem? How can we fix it?
Is there a solution to clean the pipes
Thank you in advance for enlightening me on this subject.
Val56
Deposit on pipeline
- elephant
- Registration: 28/07/06, 21:25
- x 7
What material are your channels? What is the pH of your water, directly from the roof?
elephant Supreme Honorary éconologue PCQ ..... I'm too cautious, not rich enough and too lazy to really save the CO2! http://www.caroloo.be
- Éconologue good!
- Registration: 30/09/06, 21:23
the MEC316 filter (distributed by Jetly) has an original washable stainless steel screen of 89µ, and an optional washable stainless steel screen of 50µ ...
finer, it must be disposable ....
what material your tank?
is it equipped with pre-filtration (before storage)?
if yes, which type and which mesh?
cordially
Is there a washable filter with mesh tighter than 90 microns?
cordially
well hello to you !! ...
-My tank was installed in early 2008
-It is made of concrete (5000l from Thébaut)
- anti-backwater inlet
-I suck the water 15 cm below the level thanks to a float
- my filtration before the pit is a bit random for the moment, I do tests in the manholes (30 * 30) with stockings, and currently I try headrest covers (luckily that the ridiculous does not kill )
- my pipes are mainly made of PE
Can you tell me where I can find this 50 micron sieve? The store where I bought mine did not know this sieve ...
Thank you for these responses!!!
Val56
Val56
- Éconologue good!
Re,
well it's material distributed by Jetly, so very well known ....
any merchant who sells this equipment must know or be able to order this MEC316 filter and / or its optional 50µ sieve ... !!
see product page ...
cordially
cordially
Who is online ?
Users browsing this forum : No registered users and 171 guests
