gegyx wrote:But what is this "socarex" for suction pipe?
The black polyethylene pressure hose, at 1 € per meter which is generally used for drinking water pipes?
It is indeed that. : http://www.leboutte.be/catalogue_FR_Bat ... carex.html
Replace it with black polyethylene, but it's a bit stiff for the exit of the well ... No?
It is a little rigid but by preheating it in the sun it is more
accommodating. Otherwise there are elbow fittings made for (+ - 15 €).
... it heats up with use
Wouldn't it be installed in a humid place?
If this is the case, the winding may not support
water and is poorly insulated. I just had the problem with the
pump of my swimming pool which was submerged. I let heat
the engine a few times in several days, which allowed the
dry winding. Since there is no more problem of overheating.
Unfortunately I think the bearings are dying. But
I'm losing my way ...
