oula I am not at all competent in this area.
Have you looked at the posts on the purification of rainwater?
Lagooning and phyto-purification
- Moderator
- x 11060
- Misterloxo
- Éconologue good!
- Registration: 10/02/03, 15:28
- x 1
Hi grmff ;-)
Me there was an article that I appreciated on earthships or among other things we talked about lagooning take a look here http://www.cosmic-ride.com/pages/sujets%20.../earthships.htm y even has good reading links.
Learning disobedience is a long process. It takes a lifetime to reach perfection. "Maurice Rajsfus
To think is to say no. "Alain, philosopher
Hello,
From what I have read, human excrement is too polluting compared to the treatment capacity of a personal lagoon system.
We therefore use dry toilets to make a compost from human excrement. The lagoon is used only for gray water, namely: dishwasher water, linen, sink and showers.
If you do not want to create dry toilets (because too restrictive) you have to go through a septic tank which provides a pre-treatment of wastewater that you can possibly, then, redirect to your lagoon system.
But beware, this system is very difficult to balance and you will have to perform frequent tests on the resulting pathogenic pollution.
AMHA it is better to limit the use of lagoons to gray water only, especially if you intend to ultimately create a basin to host a biotope.
some links ...
http://www.waternunc.com
Water, First Portal of the Water Economy and B2B-The Network of Water Actors
http://www.guyauxdom.com/villagenature/ ... foasis.htm
InfOasis and DG Press
http://www.ecoconso.org
The Eco-consumption Network
http://www.passionbassin.com/page1.htm
Passion Bassin, advice on how to integrate, build and maintain an aquatic garden
http://www.ecolo.be/stavelot/presse/lagunage.htm
PhilippeTherer built his own station
http://users.skynet.be/aquajardin/page50.htm
Natural swimming pool
http://www.emse.fr/~brodhag/TRAITEME/fich4.htm
- Moderator
- x 11060
I think that in this case a good solution would be to make a filtering garden ... still it is necessary to have the surface and the means to implement it (and a little green thumb;)) ... but I not know too much about water treatment ...
Who is online ?
Users browsing this forum : No registered users and 123 guests
