thank you alain G
the pump will operate according to the wind speed.
but is there not a possibility to feed my apple directly from the wind turbine to the pump its pass through accumulators and inverters.
thank you in advance.
Choose a generator for a wind turbine
mohammed
If I understand correctly, you want to accumulate water in a tank?
The problem is the height, 60 meters requires a pressure of more than 6 bars
1 meter is equivalent to 96,8 mbar X 60 meters = 5.808 bar.
You can use a stainless steel piston wind turbine. and valve with crankshaft easy to manufacture by a machine shop, everything depends on your site and the height of the blades which connected to a rod actuates the pump.
choice of generator for wind turbine
For the moment I would like to have how to demense the generator of my wind turbine is what it requires a regulation of power (tension.current).
Knowing that my pump is emerging. in a 60m deep well.
Pump characteristic:
Single-phase pump
Power 1.5kw.
Current: 10A
220 AC voltage.
Thank you, davence.
Single-phase pump
Power 1.5kw.
Current: 10A
220 AC voltage.
Thank you, davence.
- Similar topics
- Replies
- views
- Last message
- 73 Replies
- 35433 views
Last message by lilian07
View the latest post
26/06/16, 20:34A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 4 Replies
- 7575 views
Last message by chatelot16
17/11/14, 14:10A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 1 Replies
- 3406 views
Last message by Christophe
21/05/09, 19:31A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 1 Replies
- 6610 views
21/05/09, 19:34A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 40 Replies
- 60104 views
Last message by izentrop
24/02/20, 00:01A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 299 guests
