gegyx wrote:More technical message for the Gauss-man:
I don't think he can understand something, one day!
it goes to him 10 feet above his poor head
comode wrote: I save MOUAHAHAHAHAHAHAHAHAHAHA.
I'll have to make a blooper one of these 4!
gegyx wrote:---
A drop in temperature means a pumping in the energy of the vacuum.
It is better to wait for summer for the experiments, because at the moment the heating is still on.
¤ Conversion of Vacuum-Energy into Mechanical Energy under Vacuum Conditions
In order to make vacuum-energy perceptible in the laboratory the author developed a theoretical approach, which he experimentally verified with a special electrostatic rotor that converts vacuum-energy into classical mechanical energy causing a rotation of the rotor. Because all former experiments had been executed under air at room pressure, there was the request on various occasions to implement the experiment into the vacuum in order to prove, that the movement of the rotor was not caused by an artifact due to the recoil of ionized gas molecules. For this purpose the setup was now realized at the absence of air, this means within a vacuum at a pressure sufficient to exclude gas discharge. The experiments have been performed at the University of Magdeburg. It is now successfully proven that the experimental verification of conversion of vacuum-energy into mechanical energy is not an artifact caused by ionized gas molecules.
- Full Text: Article in English (PDF) (see also PHILICA.COM, ISSN 1751-3030, Article number 141, 3. Dez. 2008)
elephant wrote:A drop in temperature means a pumping in the energy of the vacuum.
We are in the big anything, there!
Indeed, we have an empathetic synergy between the Hartmann network, the Curry network, the cat ectoplasm Kelly and the machine, developed by Mylow, under the directives of St Perpette the carpenter.
Everything is connected…
when there is an unusual (exotic?) burst of energy that appears, the temperature will drop.
Sorry, Mylow made everyone doubt with his bizarre behavior. Any video editor is able to fake the demonstration that we see on a tube, glass table or not.I too mock your questions.
Because you are not about to swallow that, since even when you see Mylow's mobile running, you don't believe it yet…
gegyx wrote:I too mock your questions.
... relax.
Go back to "Innovations, inventions, patents and ideas for sustainable development"
Users browsing this forum : No registered users and 107 guests
