Over-consumption of energy on air conditioning
- I discovered econologic
- Registration: 22/03/09, 18:53
Hello, I work in offices, located on one floor of a building Heating through a three-phase air conditioning with neutral, I detected an overconsumption of energy (bill), in addition it was necessary to increase the thermostat setting to obtain a temperature of 18 ° (th = 30 °). I called an electrician who carried out measurements, and informed me that it is abnormal that the neutral at an equal or greater intensity compared to phases which they vary constantly, without being able to go into more details. I also brought in an air conditioning technician, who told me that there was no problem and that he just made an extra freon. But since its passage, it works much as before, and the setting of the thermostat corresponds to the desired temperature. Could someone explain to me in detail, technically, what the problem was. Thanking you in advance.
Hello, I have a problem of overconsumption of energy. I work in offices located on one floor of a building. Heating by an air conditioning, the first problem and that it is necessary to shift the thermostat by 10 ° more to arrive at a temperature of 18 °. An electrician took measurements on the installation (three-phase with neutral) and found that the neutral had a higher intensity than the three phases which constantly varied. asserted that there was no problem and that he just added freon. But since consumption has become acceptable again and the thermostat setting corresponds to the desired temperature. I would like to understand in detail, technically, what happened, please. Thanks in advance.
Hello dachshunds and welcome to the forum.
The problem you are describing seems to correspond to a phase balancing problem.
On a three-phase installation, it is important that the consumption of each phase is approximately the same. If this is not the case, the billed consumption will be that of the most greedy phase (it seems to me).
Ce Wiki link is quite technical but it will perhaps enlighten you.
PS: you can remove duplicate content from your message by using the EDIT button at the top right of your messages.
Hello
no fortunately, in fact you pay the sum of the consumption of the three phases so balanced or not c is the same for the consumption.
there is nothing and he is adding gas (did he at least look for the leak? if not again in the future)
your overconsumption and your difficulties in raising the temperature are due to the lack of gas in the air conditioning; you saw it yourself
in terms of the explanations of "the electrician" c is rather anything ...
an air conditioning technician, who told me that there was no problem and that he just added freon
since its passage, it works more or less as before, and the setting of the thermostat corresponds to the temperature
- Similar topics
- Replies
- views
- Last message
- 0 Replies
- 4021 views
Last message by Zhang Liao
View the latest post
24/03/16, 10:50A subject posted in the forum : Sustainable consumption: responsible consumption, diet tips
- 143 Replies
- 179933 views
Last message by PVresistif
03/02/19, 19:21A subject posted in the forum : Sustainable consumption: responsible consumption, diet tips
Back to "Sustainable consumption: responsible consumption, diet tips and tricks"
Who is online ?
Users browsing this forum : No registered users and 133 guests
