Hello, in the case of a high temperature geothermal heat pump heating installation on a radiator with buffer tank,
2 questions:
1- where is the buffer tank located, on the start or on the return circuit?
2- why and what advantages or disadvantages?
if possible contact for diagram, thank you very much
Buffer tank for high temperature geo PAC
- I discovered econologic
- Registration: 23/02/09, 11:24
Hi Jean-Luc
In your case, the buffer tank has two roles:
It will accumulate the calories to restore them later and it will also avoid a large number of starts of the compressor of the heat pump, which will improve its lifespan.
I think the ball should be mounted in parallel with the cap.
If there is a need for heating, circulation priority is given to the radiators. Once the interior temperature has been reached, the circulation is directed to the buffer tank. The heat pump runs as long as there is a cold return, ie heating is needed or the buffer tank is not fully hot.
The heat pump stops if the balloon is hot and circulation then takes place between the balloon and the radiators. It restarts when the tank is cold and there is a need for heating.
We must choose a regulation in accordance with this principle. Perhaps that of the CAP allows it?
For the diagram, I look at what exists, otherwise I will make you one
- Similar topics
- Replies
- views
- Last message
- 6 Replies
- 16941 views
Last message by francis02
View the latest post
12/12/14, 11:36A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 24 Replies
- 39665 views
Last message by ulyssesourd
07/08/09, 11:32A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 12 Replies
- 16768 views
Last message by Did67
19/11/08, 18:42A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 4 Replies
- 4847 views
Last message by langlade350
08/05/08, 15:37A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 245 guests
