Hello everyone
I decided to make a pantone engine but I have a little trouble understanding everything
I found several plans on the internet which are all different
so I turn to you to light my lantern.
first of all is that in the bubbler there is only water or water is gasoline.
in my opinion if there is a mixture of gasoline water so there is no carburetor at the entrance of the engine so I do not see either how to accelerate or how to start the engine as the whole assembly will be cold.
so if someone could inform me it will be nice
thanks in advance suempro
Need help starting a pantone mounting
Hello suempro
There are many variants for Gillier Pantone, Pantone, etc. assemblies with equally varied results.
Many things depend on what you want to achieve / do, what you have the means to implement, your knowledge of mechanics etc ...
It would be good that you start by searching with the search engine of this site to understand the principles of the system.
After a good read (rather bulky ) you will have good answers to many of your questions.
After this healthy and instructive reading, you will have lots of new, clearer ideas, and we will be happy to answer you as precisely as possible.
Reason is the madness of the strongest. The reason for the less strong it is madness.
Hello suempro
To get your teeth; it is true that the mower is a good support. For the cox engine, you should be able to find diagrams.
For the fuel-free water bubbler, this seems to me a more viable solution.
The connection of the steam outlet, I will see it rather after the carburetor, this should lessen the carburetion and the depression is more vigorous for sucking in the bubbler. Upstream of the carburetor, all the volume occupied by the steam is not occupied by air. This enriches the carburation all the more (not really the goal).
suempro wrote:but for me the simplest assembly would be a bubbler filled with water with the outlet of the reactor connected to the air inlet of the carburetor
is it possible knowing that I first want to put its on a mower engine then adapt it on a car engine (surely a cox engine
Hello suempro
The diagram + the photos of the engine + characteristics of the engine ... + statements of the original consumption on the standard lawn ...
- Similar topics
- Replies
- views
- Last message
- 25 Replies
- 23838 views
Last message by Other
View the latest post
19/03/10, 03:11A subject posted in the forum : Water injection in engines: montages and experiments
- 5 Replies
- 6657 views
Last message by jime
15/06/08, 06:36A subject posted in the forum : Water injection in engines: montages and experiments
- 1 Replies
- 3849 views
Last message by Christophe
30/05/08, 12:13A subject posted in the forum : Water injection in engines: montages and experiments
- 5 Replies
- 4988 views
Last message by denis.m21
23/05/08, 09:27A subject posted in the forum : Water injection in engines: montages and experiments
- 3 Replies
- 4622 views
09/04/08, 10:53A subject posted in the forum : Water injection in engines: montages and experiments
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 181 guests
