Hello,
today we ran our first mower. It is mounted in water doping with a tank that surrounds the reactor.
the engine to seem to turn correctly. I have some doubts about the editing. At a time the water is boiling is it that can prevent proper operation by bringing too much water into the engine?
Engine to stall after 25 minutes of operation. I cleaned the candle that seemed wet (there was a trace of oil too, it's an engine that has not worked for several years) and it's gone. The water quivered in the tank.
In the exhaust there was always a little white smoke a-but usually it was clear and the smell is not the same as conventional operation.
So I do not really know if we did well and if it worked. ..
I'll do a test with one volume of gasoline and another one with the same volume and water to see the operating time.
my first mower
Bonsoir
Is it water doping? (that water in the bubbler and your carbu instead of the origin)
or a pantone 100% with water and gasoline in the same bubbler and the mixture that passes into the reactor before being sucked directly to the intake of the engine?
In the second case the engine stall is normal.
In the first parcontre you can use too much water in the bulor and the water passes in the reactor. How are you bubbling?
Outdoors ? escape?
You do not have a shema; a photo; a drawing...
Outdoors ? escape?
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 110 guests
