Reactor improvement
- DavidHervé
- I learn econologic
- Registration: 15/09/05, 17:31
- Registration: 23/04/05, 20:23
Hello,
concerning the assembly of which you spoke previously
the goal would be to mount a dozen rods in a single tube, keeping the same iron between each rod and the tube (1.5mm)
and in what matter?
what the guy did on the Mf (except that he had put 7)? is that it?
I am a CN turner and I can allow myself to do things a little more complex in machining I could maybe try an approach !!
I have already prepared a system with 4 reactors (it is necessary that I take pictures ...) but not yet mount on tractor
you André, you have an idea on this kind of editing or inconclusive essays or things not to do (so as not to lose time) lol!
and in what matter?
- wirbelwind262
- Éconologue good!
- Registration: 29/06/05, 11:58
- x 29
- wirbelwind262
- Éconologue good!
- x 29
I think that the air gap in the case of several stems (multi-stems) should be reduced
in order to keep a fluid pressure similar to that of a single bar type reactor
I think we should tend towards
(total surface - bar surface) = surface of the standard reactor crown ~ = multi-rod surface
by drawing the model we would have for example on the left the standard reactor with the crown "section of passage of the fluid" colored in red
and on the right the section with the multi-rods ...
with these 2 approximately equal sections we should keep a similar pressure in the new reactor but with a much greater friction surface along the length of the reactor.
I let the engineers think about that ... but I think that the pressure (promoting friction) ... and the temperature ... are important.
rmq: I think that on the 1st centimeter at the input we should have conical shapes so as not to brake the fluid ... cf conical shapes of my drawing at the beginning of the post on the subject.
should i draw a section?
that's all for today ... see you soon
- Similar topics
- Replies
- views
- Last message
- 1 Replies
- 9637 views
Last message by Christophe
View the latest post
26/06/08, 19:38A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 72 guests
