Hello,
a friend and I just pantoniser a lawnmower. The engine is from 3,5 horses. We have a bubbler around the pantone for and put gas oil in it.
the carburetor was left as is and in amon there is the outlet of the reactor then there is the air filter.
the engine was started on gasoline without much difficulty (not shot for two years) and then with some adjustments of the air inlet valve it turned almost normally.
It seemed to me that it was running too fast but it's hard to realize. The engine runs 15 at 20 minutes as long as there is fuel in the tank. Then he made a noise and stalled. I was able to restart it after cleaning the candle which was oily but it stalled after a few seconds.
As a result, the engine made a sound that resembled that made by a segment in bad condition.
so there is something he did not like.
good I have some question
can we run this type of engine only with fuel?
the editing I made is it effective? the reactor outlet being placed between the carburettor and the air inlet.
does it necessarily have a control valve at the reactor inlet?
Problem on a mower
Hello
Sorry we do not see very well on your photo it seems that you installed the output of the reactor between the carburetor and the intake pipe. So it's a doping and not a pantone 100%?
Parcontre if you did like me, at the beginning I made a Pantone bubbler water / gasoline mixed and I connected the output of the reactor to the air filter of the original fuel. It only worked when there was gas in the carburetor. I thought that instead of sucking in fresh air it was enough for me to suck up gas-fueled gas for it to turn. With gasoline in the tank of carbu I start the engine so that the reactor heats then the reactor will take over. It was a mistake. In 100% Pantone you turn your carb and you suck all that comes from the reactor directly by admission.
- Similar topics
- Replies
- views
- Last message
- 5 Replies
- 7321 views
Last message by Flytox
View the latest post
01/03/09, 22:05A subject posted in the forum : Water injection in heat engines: information and explanations
- 6 Replies
- 13848 views
Last message by jime
06/05/08, 12:26A subject posted in the forum : Water injection in heat engines: information and explanations
- 38 Replies
- 34255 views
Last message by Christophe
01/01/09, 14:55A subject posted in the forum : Water injection in heat engines: information and explanations
- 14 Replies
- 12006 views
Last message by Thibounet
03/03/07, 11:44A subject posted in the forum : Water injection in heat engines: information and explanations
- 2 Replies
- 4024 views
Last message by Other
28/09/05, 05:13A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 147 guests
