The elements one by one
hi, have you tried the magnetized axis, conical and narrowed at the ends ideal for a venturi effect (d = approx 12mm - total L = 280mm), which is found in printer lazer cartridges. it is contained in a tube which seems to be aluminum (d = 14mm-int / 15mm ext - Useful L = 255mm - Total L = 265mm). the whole thing might make an easy-to-heat super reactor. let me know. a +
all with oil in the wind in the sun at the ptits zoiseaux if there is better it's all good
Wow, André, I'm afraid that one day you won't be able to leave Quebec? National treasure, prohibited from leaving territory ...
One thing is certain, and it is not me who says it but the Astrophysicists, the goal is not to prove why it works but to prove that this or that does not work, thus, the field of investigations is reduced!
Bonsoir
reply to shagaya
I completely agree with you that it makes a jolt that I no longer seek to prove that it works, but I rather seek that it works better, to improve it, what unbutton me is that there in who arrives at 50% savings and me in my best I can not exceed 30% and many times it goes around in 20% and less.
The good side is that it forces me to look even if the others have lied about the figures, it gives more consistent objectives.
reply to shagaya
André, it seems to me that the 50% is on tractors in plowing, therefore high engine speed (well for a tractor) and above all constant and a lot a lot of heat released moreover they are fuel oil, apparently it is more efficient on the latter, but the other experiences would be closer to your observations, ie 25 to 30%.
Of course I write without memme having tried the experience again, but in view of the readings of the montages, it is in fact and there is no reason to doubt the words of others.
I can't wait to find the time to do the editing, with your help of course.
- Similar topics
- Replies
- views
- Last message
- 3 Replies
- 9179 views
Last message by Christophe
View the latest post
28/06/16, 23:24A subject posted in the forum : Water injection in heat engines: information and explanations
- 25 Replies
- 23102 views
12/03/16, 03:18A subject posted in the forum : Water injection in heat engines: information and explanations
- 145 Replies
- 116336 views
Last message by Flytox
21/07/19, 22:55A subject posted in the forum : Water injection in heat engines: information and explanations
- 150 Replies
- 115923 views
Last message by Coriox
03/12/19, 11:14A subject posted in the forum : Water injection in heat engines: information and explanations
- 21 Replies
- 18049 views
Last message by yakakliker
19/07/08, 12:47A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 128 guests
