Hello
we had a house built last year and we had a rainwater recovery tank installed there (toilets and washing machine). everything worked fine but for 1 month, the pump pressure has been working once in 2. For example, when I flush the pump, the pump starts up but after 5 seconds, the pressure drops to 0 and suddenly, the pump no longer plays its role and the water does not fill the toilet. ..
anyone have an explanation?
please
Pressure problem with my rainwater recovery pump
- Moderator
- x 10972
A little vague as a question ... it is surely a problem with the blower (bladder) or a valve ...
We have a lot of cases resolved on forums: problem with water pump
But question: after only 1 year, is it not yet under warranty?
Have you looked at the suction strainer? This is where we have to start. If it is obstructed it can be the cause of the evil ...
- Moderator
- x 10972
Well, the guarantee is something that is negotiated ... especially for stuff worth several thousand euros ... Well, it is useless to say that but still ... Then it's not the tank but the pump...
But nothing prevents to call the installer! Advice is free isn't it?
Keep us in touch!
Keep us in touch!
Re: Pressure problem with my rainwater recovery pump
stephie45 wrote: For example, when I flush the pump, the pump starts up but after 5 seconds, the pressure drops to 0 ...
Question: does the pump motor work
still or not after 5 sec?
The causes can be:
- defused pump
- motor thermal switched on
-turbinue of the pump blocked by a strange body
-rocked water supply.
-etc...
and suddenly, the pump no longer plays its role and water does not fill the toilet ...
This is the consequence of the problem, more than finding the cause.
- Registration: 12/01/07, 08:18
- x 4
- Similar topics
- Replies
- views
- Last message
- 29 Replies
- 16298 views
Last message by oli 80
View the latest post
13/06/21, 11:11A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 11 Replies
- 22073 views
Last message by izentrop
09/02/21, 09:50A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 1 Replies
- 8484 views
Last message by thibr
28/07/18, 07:16A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 3 Replies
- 6534 views
Last message by Ahmed
18/05/18, 22:18A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 7 Replies
- 11535 views
Last message by Bardal
08/04/18, 18:07A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
Who is online ?
Users browsing this forum : No registered users and 123 guests
