To laugh a little!
I did this for students!
but it's better to use recycled water!
the mini hydroelectric plant
You have probably seen it before ??
http://www.dailymotion.com/Jeidii/video/x5vvp8_hydroelectricturbine_tech
Chao!
Micro Turbine and tap water energy?
Hello,
in the same vein there is also this realization which is not bad (but there it is a question of waterfall):
http://www.moreau-fr.net/proto/turbine/index.html
The absurdities of yesterday are the truths of today and tomorrow banalities.
(Alessandro Marandotti)
renaud67 wrote:Hello,
I just had a look on your site, and it's really great !! on the other hand I did not understand too much, your mill will not work 24/24 is that right?
In any case it is really not bad, there can be something of this kind has to make for the robines of the house which would provide a little more current.
It is true what a compatriot said above, it is preferable to use one of this way for powered a hair dryer or other but I do not believe that this is really feasible.
I would have a few questions to ask someone who knows a bit about electricity because there are places where I can still dry a bit, if someone would have time for me in MP this would be great!
Hello
I came across this forum by looking if something existed to recover the pressure energy from tap water ...
I like the turbine shown by Renaud67, it maintains the flow but uses the pressure and can therefore be used to fill for example a bathtub (the pressure does not matter then, only the flow counts).
You talk about the problem of pressure loss at the valve outlet;
as for me, I was thinking of a solution that would allow this pressure loss to be regulated, in order to convert it entirely (to the nearest yield) into electrical power.
Let me explain: it would be possible to use, for example, an axial turbine with variable blade incidence, coupled with an all-or-nothing valve. When we open the "valve", we open the valve fully and we act on the incidence of the blades.
For a small flow, the blades have a very strong incidence: the turbine turns quickly, it converts a large part of the energy of the water into electricity: the water leaves with a small flow.
For a large flow, the blades are feathered: the turbine does not turn, the water retains all its energy.
This requires a small mechanical device for the orientation of the blades; nothing complex (for an industrial plastic manufacturing for example).
But you can also use a fixed turbine and regulate the generator current to control the flow.
Such a system would make it possible to use the pressure drop of the water, normally lost in heat in a simple tap ...
On the other hand, the exploitation of the electrical energy thus created remains to be defined Put a battery, an inverter and synchronize to the EDF network? A bit complicated ... Powering the bathroom lamp (LEDs for example)? ...
- Similar topics
- Replies
- views
- Last message
- 0 Replies
- 6256 views
Last message by Peter0922
View the latest post
02/02/22, 11:52A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 73 Replies
- 35270 views
Last message by lilian07
26/06/16, 20:34A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 38 Replies
- 15035 views
Last message by Macro
10/01/13, 10:29A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 1 Replies
- 4365 views
Last message by minguinhirigue
04/03/12, 16:04A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 15 Replies
- 9218 views
Last message by oli 80
11/03/12, 19:05A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 169 guests
