Pantonisé the engine of my boat
Edits and changes to engines, experiences, findings and ideas.
bolt
Éconologue good!
Éconologue good!
Registration: 01/02/06, 20:44
Re: Pantonisé the engine of my boat
by bolt » 08/10/08, 22:11
hello grandpa stone
grandpa Stone wrote:I put a propeller 24 / 20 and it turns to 1400 see 1500tr / mn for 8km and + - 1600 1800tr / mn for 10km / h
24 / 20 means what exactly, in metric dimensions :?:
you could have even put an even bigger one to run your engine at 1100 rpm for 10 km / h to consume less
pity that there is not a gearbox, you could have tried different report and note the consumption for each speed while staying at 10 km / h
at most the engine is loaded, at least it will consume in relation to the work produced
in your case, it is necessary that it turns as slowly as possible while making you advance to your 10 km / h
bolt
Other
Pantone engine Researcher
Registration: 17/03/05, 02:35
x 12
by Other » 12/10/08, 03:58
Hello
Bolt wrote:hello grandpa stone
bolt
In the standard one always expresses a propeller by is diameter and its not even for the planes (except in France each helicopter has numbers which relates to which I never understood)
24 20
24 inches in diameter = 61cm
20 inch of pitch = 51cm
On a cessna 172 propeller Mac Cauley DTM 75 53
either a 75 "suede and a 53" pitch
On a fast engine 5,7litre V8 250CV 3800 rpm petrol engine we put an 16 19 in aluminum
Propeller under repair that hung the bottom
Bibiphoque
I posted 500 messages!
Registration: 31/03/04, 07:37
by Bibiphoque » 13/10/08, 09:32
Hello,
: Mrgreen: : Mrgreen:
André will end up with an ISF, since he has a fast boat !! : Mrgreen: : Mrgreen:
This is not because we always said that it is impossible that we should not try :)
User avatar
Former Oceano
Moderator
Moderator
Registration: 04/06/05, 23:10
by Former Oceano » 13/10/08, 22:35
ISF in Canada?
I do not think so... : Mrgreen:
[MODO Mode = ON]
Zieuter but do not think less ...
Peugeot Ion (VE), KIA Optime PHEV, VAE, no electric motorcycle yet...
User avatar
Registration: 21/01/05, 11:59
x 2914
by gegyx » 27/09/09, 14:40
User avatar
coucou789456
Registration: 22/08/08, 05:15
by coucou789456 » 27/09/09, 20:44
Good evening
in the wake of what is sent gegyx, https://www.econologie.info/share/partag ... vuODpk.pdf
origin of the document: the 16 September 2009
jeff
User avatar
coucou789456
by coucou789456 » 27/09/09, 20:51
re Goodnight
why for the houseboat, do not opt ​​for a smaller engine driving an alternator, with batteries and electric motor of 20 Kw, it should be enough, and possibility of small maneuver only batteries ...
a hybridized barge in short.
jeff
User avatar
Moderator
Moderator
Registration: 13/02/07, 22:38
x 839
by Flytox » 27/09/09, 21:29
This subject reminds us that Bolon is transparent for a few months ...... : Cry:
Reason is the madness of the strongest. The reason for the less strong it is madness.
User avatar
Cuicui
Registration: 26/04/05, 10:14
x 6
by Cuicui » 27/09/09, 21:33
coucou789456 wrote:why for the houseboat, do not opt ​​for a smaller engine
Hello Grandpa Peter
You have made the situation very clear: this big engine was not expensive and you would like to make it work in the most economical way possible.
Putting a smaller engine is theoretically a good solution but may result in unrealistic costs.
Since this engine is installed, how to pantoniser it?
Would a larger or faster propeller not allow more engine loading and enough exhaust temperature to allow the operation of a Pantone reactor?
User avatar
Cuicui
x 6
by Cuicui » 29/09/09, 19:32
grandpa Stone wrote: I am a small handyman but do not start or c, with a SPAD or a bubbler? how to build one or more correct reactor which dimension ect.
I'm trying to bring this up because I feel that Grandpa Peter did not find a real answer to his question.
Personally, I am not a pantoniser, so I am not competent, but I suppose that the first step is to measure the temperature of the exhaust to check if it is sufficient to allow the operation of a reactor.
Once this is done, contact the Spad manufacturers, for example, for advice, as they are used to pantonizing tractors that are similar to those of a boat engine.
  • Similar topics
    Replies
    views
    Last message
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 81 guests
