re
for nlc, I appreciate your answer, at least you don't add a derogatory remark like that of obelix
jeff
electrolysis improved
- coucou789456
- Grand Econologue
- Registration: 22/08/08, 05:15
- Registration: 12/01/07, 08:18
- x 4
Well let's be clear: your assembly will not make more gas than the 6 cell reactor powered directly on 14V.
Now stop posting on my subject you start to inflate everyone. If you want to advertise your stuff do it elsewhere.
You have no luck there you came across people who have serious experiments on the electrolysis of water and who know what they are talking about.
Re: re: nlc
gaudet86 wrote:So here if I understand correctly nlc you confirm that you are doing hydrolysis under the law of faraday is that it ??
and great I would like to know more about that .. !! ;)
you fuck under 1.7 volt ?? and it increases ?? if I go down to 0.5 volts per cell it will be even better ?? here we hold our plates at a distance of 1mm without nosh and we climb to 20 ampere 12volt to obtain 3-4 liter / minute / cooled by radiator + pump.
Now do you do flow measurements? you weren't doing it earlier or yesterday. Well, there is progress!
gaudet86 wrote:I understand your principle, I understood the principle of dingel too and that of meyer, several of tesla above 20 and then .. here we talk about delectrolysis amelioerer meyer has this place here too .. resonance type is another type cest all ..
you can break a glass by singing, you can do it with a hammer or by putting it at 3000 degrees, the water is the same ..
with aluminum also it seems to give very good results .. but it is deguelass.e.
Are your results below Faraday law?
you say get a better result / so if i understand + that faraday is that it?
Did you understand the principle of meyer, we're happy for you, but did you make it work? Are you going below 2.34W / h per liter of gas generated?
- Capt_Maloche
- Moderator
- Registration: 29/07/06, 11:14
- x 42
EH! have you finished bickering?
We know that Meyer proposed to dissociate water from cells which act as Capacitors; Just put 2 stainless steel lacquers in the water to see as I did here https://www.econologie.com/forums/fabricatio ... 70-90.html
I wanted to measure the resistance of my cell: well no, it charges with my 9V measuring device ...
Meyer says he has managed to dissociate water to the point of being able to run an engine from the electrical energy produced by the same engine, which means exceeding at least 20 times Faraday's law ...
He also said that it was necessary to look for a formidable "explosive" energy towards 40Kv I believe ...
All this, some have tried, no one to my knowledge has reproduced it ...
We can always believe it, BUT, IF PEOPLE SAY THAT THEY ARE OPERATING A HEAT ENGINE WITH IT, I WOULD LIKE TO SEE IT PLEASE and I would make the trip to CANADA if necessary.
for the stainless steel tube, I have a friend who got me several lengths in pharmaceutical quality, I don't have long to tinker with a contraption ...
and then, why tubes and not plates?
this tube resonance story does not stand up if the tubes are fixed high and low ...
"Consumption is similar to a search consolation, a way to fill a growing existential void. With, the key, a lot of frustration and a little guilt, increasing the environmental awareness." (Gérard Mermet)
OUCH, OUILLE, OUCH, AAHH! ^ _ ^
- I posted 500 messages!
- Registration: 31/03/04, 07:37
nlc wrote:Christophe help !!!!!!
Is not there a model that could banish this cretin? It rots my subject or had a good atmosphere!
Hello,
I anticipate that there will be cleaning in the near future!
(I just zap ...)
This is not because we always said that it is impossible that we should not try
- Moderator
- x 11060
Re: ah handsome conqueror
gaudet86 wrote:bye you coune
I've lost enough time here
Well it's good guys it breaks without our intervention ...
Sorry I was (rare) OFFLINE all the weekend.
Hydrogen in on-board generation which is not generated by the losses of a vehicle (brake recovery) is pipo.
And bubbles in an electrolyser, even a lot like on Meyer videos proves absolutely nothing ... as to the viability and the savings that the system allows!
Didn't Pkoi Meyer make and sell generators with water so that they no longer had to pay their electricity bills? Let us ask ourselves the right questions ...
- Similar topics
- Replies
- views
- Last message
- 1 Replies
- 10990 views
Last message by elephant
View the latest post
04/05/13, 16:45A subject posted in the forum : special motors, patents, fuel consumption reduction
- 248 Replies
- 42257 views
Last message by GuyGadeboisTheBack
04/12/23, 20:56A subject posted in the forum : special motors, patents, fuel consumption reduction
- 59 Replies
- 40602 views
16/11/08, 17:49A subject posted in the forum : special motors, patents, fuel consumption reduction
- 13 Replies
- 30631 views
Last message by Christophe
01/12/08, 21:30A subject posted in the forum : special motors, patents, fuel consumption reduction
- 11 Replies
- 16891 views
Last message by zac
07/12/06, 21:22A subject posted in the forum : special motors, patents, fuel consumption reduction
Back to "Special motors, patents, fuel consumption reduction"
Who is online ?
Users browsing this forum : No registered users and 165 guests
