tesla special coil:
then ray my back, it's a classic coil that? or something of +?
Nikola Tesla explains that a standard winding of 1000 towers with a potential of 100 volts across it will have a difference of 0.1 volts between turns. A similar winding of BIFILAR will have a potential of 50 volts between turns.
Because the stored energy is a function of the place of the tensions that the energy in the BIFILAR will be ...
50 have adjusted / 1 squares = 2500 / 01 = 250.000 times larger than standard winding
patent:
http://www.magnetricity.com/NeoG/Bifilar.php
to translate web pages in real time:
http://babelfish.altavista.com/
"in my opinion" to reproduce this mechanically will take time ...
as for the detraceturs of "overunity" the author specifies:
PERPETUAL MOVEMENT: The Inevitable Question *
How this notion haunts us all ... our primary ridiculousness of narrowness (?) Let me be absolutely clear on this point, this is not, in any way, a perpetual device of motion. Thank you. *
Perpetual motion implies eternity. Nothing synthetic is eternal. Neither will this feature run forever. This is the way of all technology. *
Eventually, the component will failure or wear out physically or electrically resulting in enough downtime to replace or repair the component. Afterwards, the device can be restarted and run until the next failure. *
HOWEVER, the recent availability of iron-accessible neodymium boron rare-earth permanent magnets brings us closer than ever to realizing such a device. *
My main goal is to maximize the energy produced and the run time and to minimize the downtime by minimizing energy losses as much as possible such as heat, wear, friction, drag, vibration, etc. and by the choice of materials for extended life. The usefulness of such a device in rural or desolate areas of the world should be obvious to anyone.
Other original "magnetic motor"
Yes, I was talking about the Macder,
You know, when you have an alternator with 95% efficiency, there is not much to improve
I admit that this is not my field of research, we can not be brilliant everywhere
On the Robiplan, we do not perfect the Pelton, Pascal has "released" a new very different thing.
We just came to talk about it by reference to "the state of the art".
And it's immediately more pleasant when we speak nicely
oliburn wrote:.........
Why are you laughing Olburn
Strip My Back to Play Draw
This Tesla thing does not store much if the wire is not traversed by INTENSITY.
A stationary voltage does not store anything, unless you have capacitors, that is to say 2 conductors in total influence separated by an insulator.
Finally, I looked at it diagonally ... it's a "top speed" judgment
To see again!
don't say that Tesla did "stuff" nobody comes close to him ... besides, do you know when the film on his life will be released with david bowie as the interpreter?
have you ever seen the white stripes running one of his machines in "coffee and cigarettes"?
Obviously, the current travels through these coils, and that there are capacitors.
so I want to respect you but if you do not respect these inventions then you will have the same from those who listen to you!
or want to listen to you, depending on.
I have already told you about the concern for the alternator ...
well since you want to prove yourself on this forum and that often here "only the result counts": therefore connect an alternator on a wind turbine and announce the yields, with battery regulator etc!
"something concrete, not patents"!
Remundo wrote:You know, when you have an alternator with 95% efficiency, there is not much to improve
- tigrou_838
- I posted 500 messages!
- Registration: 20/10/04, 11:25
Re: macder
is this dear Mr. Goldschmidt in contact with the one who bought his invention?
can he give a marketing date for his inventions?
Hello everybody
This case is relatively complicated, yes rights have been redeemed,
not by the person posting the videos.
Developments with regard to this product are in progress.
But to know if something will come out there is another story.
Know that Harry's model worked beautiful and well,
But beyond the general concept, the system is rotten in nuance and details and in skill.
not knowing them, it is all the development that must be resumed.
The element that appeals to me in the file that I gathered is the assumption that a magnetic field can be compressed !!
Many analogies are made with the behavior of fluids or gases.
For me it is new is it founded or not, I want to work on the subject.
A + + +
PS: the tests will start shortly jonule, I drool too.
A + + +
Every minute that passes is an opportunity to change the course of your life.
YouTube page, Dailymotion page, Picasa album, personal Pages, Viktor Schauberger
- Similar topics
- Replies
- views
- Last message
- 0 Replies
- 5779 views
Last message by Seed
View the latest post
24/11/21, 13:57A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
- 0 Replies
- 3521 views
Last message by prenma
28/09/04, 05:25A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
Go back to "Innovations, inventions, patents and ideas for sustainable development"
Who is online ?
Users browsing this forum : No registered users and 197 guests
