How to install pantone system on a petrol engine? I have a diagram
please
Pantone on petrol engine
- Moderator
- Registration: 10/02/03, 14:06
- x 11060
Re: Pantone on petrol engine
essence wrote:How to install pantone system on a petrol engine? I have a diagram
please
Do you want a diagram? So here is a diagram: https://www.econologie.com/le-plan-origi ... -2167.html
Do a image search or an text search - Netiquette of forum
thank you bk
my I see a diagram of an 8CV petrol engine with photos
please
please
- rezut
- I understand econologic
- Registration: 01/12/04, 14:58
- x 2
you see example here
http://perso.wanadoo.fr/quanthommesuite ... antone.htm
or
you just have to make a choice
but if you thought to find an installation with diagram and dimensions for a given type of vehicle it is grated
it's up to you to read and take what best suits your needs
or
- Former Oceano
- Moderator
- Registration: 04/06/05, 23:10
Photos for 8CV engines I used the search liar gogol.
He gave me the following links:
http://www.buycentral.fr/info/16188050794719954113.html
http://www.helica.info/modele.htm
http://www.teamquad69.izispot.com/perso-1723512.htm
- Woodcutter
- Registration: 07/11/05, 10:45
- x 2
Hello
For the plan provided on econology
There is a problem with converting measurements
When we talk about pipe 1/2 pipe it is not 12,7mm
ditto for the reactor shell which is a 1 inch pipe.
Original dimmension provided by Panton
The reactor body is a 1/2 pipe
L, reactor shell is 1 inch pipe
The rod is 1/2 inch so 12,7mm
the length is 1 foot or 12 inches
The thing to know is a rod with an aperture of approximately 1mm and a length of 150mm more or less
and an envelope tight enough around the heater to heat as much as possible without making too much restriction on the exhaust gas
a 12 mm outlet pipe and having a good vacuum in the reactor, all the rest is plumbing.
Andre
Andre
- Similar topics
- Replies
- views
- Last message
- 0 Replies
- 6871 views
Last message by Christophe
View the latest post
14/06/16, 23:04A subject posted in the forum : Water injection in heat engines: information and explanations
- 22 Replies
- 33227 views
Last message by Flytox
08/12/13, 11:57A subject posted in the forum : Water injection in heat engines: information and explanations
- 0 Replies
- 11667 views
Last message by carmelo42
03/05/13, 09:33A subject posted in the forum : Water injection in heat engines: information and explanations
- 13 Replies
- 29594 views
22/03/16, 23:19A subject posted in the forum : Water injection in heat engines: information and explanations
- 5 Replies
- 19159 views
24/10/12, 19:39A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 154 guests
