Hi Elephant,
When I said (supposed) free, for everyone, we don't make an omelet….
Obelix fell into the magic potion okay, but someone knows how to make it easily, the potion (I dream of course).
For the two million euros, it's a bit light so that I worry, I assure you. (if I understood the meaning correctly)
The industrial project is probably more exciting, you're right, now the economy of today really freaks me out when it comes to its future.
I was reading this this morning: raid-in-the-belarusian-stores.
A ++
Spending intelligently 500 free electric W
- elephant
- Registration: 28/07/06, 21:25
- x 7
By the way, Obélix .....
It's been 4 and a half months since you asked us this question:
and you play dead ...
What was the thing?
I have a machine that sends me 100 V under 5 A DC.
And this 24 / 24 7 / 7 and absolutely free. The only constraint is to grease from time to time two ball bearings.
What is the most intelligent way to consume this energy?
What was the thing?
elephant Supreme Honorary éconologue PCQ ..... I'm too cautious, not rich enough and too lazy to really save the CO2! http://www.caroloo.be
- elephant
- x 7
Thank you, Del, but I would have liked him to say it himself: salivating is good ... filling up is better!
Bjr,
In order to satisfy your immense curiosity:
An autonomous "engine" based on the work of klaus Turtur
http://www.ostfalia.de/cms/de/pws/turtur/FundE/English/
But it's very cotton ... I have a good copy and I don't know why! And another who refuses to step up ...
Obelix
Obelix
In medio stat virtus !!
- elephant
- x 7
Why "joker"?
I have known Obélix since I haunt these forums, he was there before me. I look at the links he gave us to see if there is an assumption that it is not working.
For the rest, Obélix: finally what do you do with those 500 watts?
(I have a new answer: heat a Focardi-Rossi boiler )
To make us salivate:
with totally false theoretical turtur simulations, scientifically based on exact classical equations (conserving them energy), which if true, would make cell phones machines with zero point movement, perpetually running without batteries or batteries !!
The energy of classical and quantum fields is preserved, verified since Maxwell (in 1863) !!
So doubts and great chances of basic errors, like the huge mistake on the simulation of classical field equations and Turtur simulations !!!
The piezoelectric gas lighters, with piezo (capacity with mechanical movement of the plates coupled with self and external resistance of the circuit) should work perpetually !!
Turtur makes a basic error in its simulation with discretized computer equations which do not check the conservation of energy, whereas energy conservation is checked on its initial equations in differential form !!
So he finds energy supplied by his false computer simulation.
Well known for any computer simulation which can be arch false with accumulation of rounding errors !!!
Does the copy that seems to work keep it working if it is moved elsewhere ???
The measurement of the 500W is it exact or false, because there are easy traps in the power measurements, as in the computer simulations of Turtur, which crashes !!
- elephant
- x 7
Found by exploring the links linked to those of Obélix:
http://www.ostfalia.de/export/sites/def ... nately.pdf
click, it's worth .....
Obélix, under penalty of losing your credit on ecomologie.com, publishes at least 2 minutes of video on Youtube or vimeo .....
- elephant
- x 7
Well, there is still more encouraging:
http://philica.com/display_article.php?article_id=219
and, indeed:
If it's a machine like this that you managed to tinker with, the most rational use is actually to calculate a resistance to heat water.
Now, does it still take a lot of energy to rotate a magnet at 6000 rpm? no ?
There is something that bothers me: Turtur or one of his friends should be rich by now, right?
and, indeed:
As soon as the system is adjusted, the motor will run stable, as long as we do not try to extract more energy then the motor can deliver. (For more energy we should use a larger motor.) Our Motor has a diameter of 9 cm and a height of 6.8 cm - so this is not very much - and we will soon see that it produces a power of 1.07 Kilowatt. On the other hand, if the load is decreased, the power production will be decreased. This is a feature of the system, because the system never can overtake the state of “energetic saturation”.
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 431 guests
