Hello,
I am a student and I have a project with a wind turbine. For the moment I would need several answers to my questions to be able to find certain devices.
I have an air wind Land X 400W 12V integrated regulation and I would like to know:
- with what kind of device (sensor if possible) it is possible to measure the energy which product at output.
- with which device can we measure the wind speed.
- is there a mathematical formula that would determine the energy produced by a wind turbine as a function of wind speed.
The values that I will retrieve will be displayed on an LCD screen normally. So if possible, I would like it to be a sensor.
For the moment I have no other question but there will surely be some that will come later.
I thank you in advance.
Wind help: energy balance
Re: Wind aid: energy balance
guillome wrote:I have an air wind Land X 400W 12V integrated regulation and I would like to know:
Well with a Watt meter. Or several multimeters to measure voltage, current and cos phi (if the machine leaves the alternative).
guillome wrote:- with which device can we measure the wind speed.
Well with an anemometer. There are simple ones with cups, or complicated ones with ultrasound. Anyway, as with any sensor, the more precise it is the more expensive it is. And you have to calibrate properly.
guillome wrote:- is there a mathematical formula that would determine the energy produced by a wind turbine as a function of wind speed.
Of course. There is a theoretical formula called Betz's law.
The demo and the explanations over there et over there. And read the rest of the site, it's just good.
It tells you the maximum energy recoverable in the case of a perfect wind turbine. But as your machine is not perfect, you have to take the manufacturer power curve giving the electric power according to the wind speed.
guillome wrote:The values that I will retrieve will be displayed on an LCD screen normally. So if possible, I would like it to be a sensor.
The anenometer which returns digital signals is what is used by professionals who record data over a year (in general). After will find out the price of the sensors ... You must inquire at suppliers.
- Moderator
- Registration: 10/02/03, 14:06
- x 11043
Rulian wrote:Well with a Watt meter. Or several multimeters to measure voltage, current and cos phi (if the machine leaves the alternative).
Well a wattmetre measures instantaneous power but does not measure energy ...
In his case he would need an equivalent of the PM230 ( https://www.econologie.com/shop/economet ... prise.html ) but in 12V ... unless it goes through an inverter to make 230 AC (the PM would work) but in this case the losses of the inverter would not be compatibilized, it would therefore be necessary to correct with respect to the inverter efficiency ...
Otherwise thank you for the reminders of wind physics (I hadn't answered hoping for an answer from you)
Do a image search or an text search - Netiquette of forum
- Similar topics
- Replies
- views
- Last message
- 1 Replies
- 2661 views
Last message by Christophe
View the latest post
24/05/16, 19:14A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 10 Replies
- 7139 views
Last message by Ahmed
26/03/16, 19:34A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 31 Replies
- 22118 views
Last message by Petrus
06/12/16, 17:46A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 9 Replies
- 5368 views
Last message by elephant
19/11/15, 17:35A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 2 Replies
- 3551 views
Last message by sycholote
24/11/15, 07:04A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 247 guests
