Hello,
for opinions, observations, remarks,
what do you think of a hydraulically opening gate, the counterweight of which opens with a hydraulic supply simply controlled by one or two controlled valves (depending on the variants), water from the "retention" tank C can also, in part, go back into tank A, with a "Heron's Fountain" style assembly.
PORTAL with hydraulic opening
- Former Oceano
- Moderator
- Registration: 04/06/05, 23:10
In winter you will have interest to put antifreeze ... Otherwise your gate will not be able to open ...
An electric motor with a small solar panel and a battery will be safer ...
[MODO Mode = ON]
Zieuter but do not think less ...
Peugeot Ion (VE), KIA Optime PHEV, VAE, no electric motorcycle yet...
Hello Alain and Océano,
Thank you for your opinions,
- concerning the gale, a priori if it is a "heavy" barrier, this will have no impact,
- Regarding the car window regulator, it is indeed to be seen, but we have to check what force can it develop?
- ok seen for antifreeze!
- 12 volt electric motor + solar panel + battery, actually it's good but unfortunately it's a significant investment and the location where the gate is can easily be stolen, so it's sensitive,
- you have to find the most simple and rustic way to open and close one or two hydraulic valves remotely (depending on variant), maybe: solenoid valve powered by a pulse by remote control?
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 278 guests
