I display the greatest caution when faced with this announcement:
http://www.wikistrike.com/article-energ ... 52420.html
from the can, because it's a snake that bites its tail or does it work?
What do our thermodynamicists think about it?
Stirling + PAC: snake biting its tail?
- elephant
- Registration: 28/07/06, 21:25
- x 7
elephant Supreme Honorary éconologue PCQ ..... I'm too cautious, not rich enough and too lazy to really save the CO2! http://www.caroloo.be
- Moderator
- Registration: 10/02/03, 14:06
- x 11042
A snake that bites its tail is a Ouroboros and it is ... a legend!
http://fr.wikipedia.org/wiki/Ouroboros
Do a image search or an text search - Netiquette of forum
- Registration: 11/11/07, 17:33
it is the principle of all perpetual movement! make it complicated enough not to know how to calculate it exactly, make some miscalculation to believe that it works
basically a heat pump, heat pump to the ambient air, and thanks to its good COP gives heat which does not cost much to a thermal engine
carnot calculated all this a long time ago
Maximum COP of a heat pump is exactly the opposite of the maximum efficiency of a heat engine at the same temperature!
if the heat pump has a theoretical COP of 5 it will operate a motor with theoretical maximum efficiency 1/5
result 5 x 1/5 = 1
and since the actual result is less than the theory: profit = loss
it's as bad as the electric motor that turns a dynamo that powers the motor
result 5 x 1/5 = 1
Hi Elephant
Since there is no cold source (only one heat source, the ambient air), this is impossible.
If you want to see serious things and thermally surunitary, look here... If we had clever industrialists and a real energy policy, they would offer these things (PAC + Stirling cogeneration coupling), and we would no longer have a blackout in winter
Here is the schematic plan of a device that can produce energy in electrical or mechanical form, from the heat of the ambient air.
- elephant
- x 7
So I did well to be wary (what I said at the opening of the post).
Goods.
Goods.
- Similar topics
- Replies
- views
- Last message
- 1 Replies
- 25733 views
Last message by bobono
View the latest post
27/02/08, 19:45A subject posted in the forum : Fossil fuels: oil, gas, coal and nuclear electricity (fission and fusion)
Go back to "Fossil energies: oil, gas, coal and nuclear electricity (fission and fusion)"
Who is online ?
Users browsing this forum : No registered users and 306 guests
