Hi everybody
The magnetic effect on a fluid is related
with the displacement of it
Or vice versa !
make a 10cm loop in the hose circuit,
install a 10cm disc with permanent magnets,
put it in rotation at 5.000, 10.000 or 20.000 rpm
you will get a relative velocity between fluid
and magnetic field
25 m / s, 50 m / s and 100m / s
Preferably: the loop would be a flat tube (flattened)
which brings the fluid closer to the magnet and increases the effect
This is the mechanical version,
the electronic version remains to be seen.
(magnetic pulses at 2 Giga Hz what does it do?)
Magnetic treatment of a fluid or fuel
- Capt_Maloche
- Moderator
- Registration: 29/07/06, 11:14
- x 42
Hue? hello hic
What is the purpose of the maneuver?
Fluids are not sensitive to magnetic fields, unless they are crossed by an electric current (see MHD), induced or other, or maybe if they are ionized
"Consumption is similar to a search consolation, a way to fill a growing existential void. With, the key, a lot of frustration and a little guilt, increasing the environmental awareness." (Gérard Mermet)
OUCH, OUILLE, OUCH, AAHH! ^ _ ^
Back to "Special motors, patents, fuel consumption reduction"
Who is online ?
Users browsing this forum : No registered users and 186 guests
